GTA Laundry Room Renovation and Addition Guide 2026
Laundry Room Renovation and Addition for GTA Homes 2026
A well-designed laundry room adds daily convenience and is a top-10 buyer preference in GTA resale surveys. Whether upgrading an existing space or adding laundry to a new floor, this guide covers everything you need to plan.
Best Laundry Room Locations
Location Pros Cons
Main floor Most convenient, minimal pipe runs Requires dedicated space
Second floor Near bedrooms, no laundry hauling Requires drain stack extension, floor waterproofing
Basement Traditional, good for large setups Longest trip, less convenient
Laundry closet Space-saving, stacked units 32x32 ft minimum, limited storage
Plumbing Requirements
  • Hot and cold supply (3/4" main, 1/2" at machine)
  • 2-inch standpipe and P-trap, minimum 18" above trap
  • Proper venting (AAV or tie-in to stack)
  • Flood stop automatic shutoff valves recommended ($150-300)
Electrical Requirements
  • Electric dryer: dedicated 240V/30A (NEMA 14-30)
  • Gas dryer: 120V/15A + gas line
  • HE washer: dedicated 120V/20A
  • GFCI within 1.5m of laundry tub
Dryer Exhaust Venting
  • Must exhaust to exterior (rigid metal duct — never flexible foil)
  • Maximum equivalent length: 7.5m (25 ft)
  • Deduct 1.2m per 45-degree elbow, 2.4m per 90-degree elbow
  • Clean annually — lint buildup is a fire hazard
Storage Design
  • Folding counter above front-loaders at 25" depth
  • Overhead cabinets at 42" from counter
  • Hanging rod for air-dry items
  • Built-in ironing board (space-saver)
Cost Guide
Scope Cost
Laundry closet (new) $3,500-8,000
Room renovation (existing space) $5,000-15,000
New second-floor addition $12,000-30,000
Connect with GTA plumbers and renovation contractors on home.renovation.reviews.
LF Builders designs and builds laundry rooms across the Greater Toronto Area. lfbuilders.ca
