GTA interlock front walkway in 2026: base prep, the salt damage most quotes ignore, and what a complete scope covers
The front walkway gets overlooked on most quotes. It’s not the biggest scope item, and contractors often price it quickly or bundle it with a driveway without thinking through the site-specific details. That’s a problem, because a front walkway in the GTA takes more punishment than almost any other exterior surface, and the failure modes are specific to how the job is set up.
Why a walkway is harder than it looks
A standard front walkway runs 100 to 180 square feet, a fraction of a driveway, but the complications don’t scale down proportionally.
Access is usually tight. Most walkways run through a narrow corridor alongside the house or directly up the front yard with no room for equipment. All the base material, aggregate, and finished stone comes in by hand or with a small wheelbarrow. That’s slower than a machine-accessible driveway, and the labour cost per square foot reflects it.
Salt exposure is worse than anywhere else on the property. A front walkway borders the public sidewalk, where city salt trucks run. The walkway takes direct salt splash from the street, plus whatever the homeowner applies in winter. That salt load concentrates in a small area and compounds damage faster than it would on a larger surface with more dilution area.
Visibility is higher. The front entrance is what visitors and buyers see first. A settled joint, a colour mismatch, or an uneven edge is immediately obvious at eye level. On a back patio, nobody notices until they’re already out there. At the front door, it’s the first thing they see.
The base problem in GTA clay
Ontario’s frost depth in the GTA runs 1.2 to 1.5 metres. A front walkway base that doesn’t account for that will heave, which opens joints between pavers and creates uneven surfaces that become both a trip hazard and a drainage problem that gets worse each season.
The failure pattern on cheap walkway jobs is consistent: 6 to 8 inches of crushed aggregate, looks fine year one, and by year three the clay below has moved and there are peaks and valleys across the surface. The pavers are fine. The base wasn’t deep enough.
For a walkway in GTA clay, 10 to 12 inches of compacted granular base (Granular A or B) is the minimum, installed in lifts of 4 inches or less and compacted after each lift. The bedding layer sits on top of that without getting compacted after the pavers are laid. When contractors compact the sand after the pavers are set, it locks up and loses the minor settlement accommodation that keeps the walkway looking flat over time.
If a contractor says 6 inches and doesn’t mention compaction lifts, the price is low for a reason.
Which paver surface holds up to salt
Smooth-face and polished pavers look clean when new. Salt is a problem on them. The reaction leaves white residue that builds up on smooth surfaces and is hard to remove fully between seasons. On a glossy paver, it’s visible constantly.
Tumbled or antiqued pavers have broken, irregular edges. Salt residue settles into the texture and becomes much less noticeable. The same amount of salt damage reads as character on a tumbled surface and looks like neglect on a polished one.
Sealing helps with salt penetration, but timing matters. Sealing right after installation traps moisture under the paver face and accelerates spalling. The right sequence is to seal after the first full winter, once the surface has cured, been cleaned, and fully dried. If a contractor offers same-day sealing at the end of installation, that’s backwards.
On colour: lighter stones (tan, sandstone, ivory) handle salt deposits better visually than dark pavers. High-contrast borders also make settling more obvious later, worth thinking about before you commit to a dark field paver with a light border.
The right-of-way check most homeowners miss
In Toronto and across most GTA municipalities, any work within the municipal right-of-way requires a utility locate before digging. That strip of grass between your property line and the sidewalk looks like your yard, but it’s not your jurisdiction for construction purposes. Ontario One Call (1-800-400-2255 or online) handles the locate for free, and the contractor needs to confirm it before breaking ground.
Toronto requires a Road Occupancy Permit if equipment will block the road or sidewalk, even briefly. Vaughan and Mississauga have the same rule. The permit takes a few days to process and affects when the job can start.
If a quote doesn’t mention locates or ask about right-of-way proximity, the contractor hasn’t done the pre-job check.
What the job should cost in the GTA
A front walkway at 120 to 160 square feet, standard Holland paver, full base prep to 10 to 12 inches, granular edging, and debris removal typically runs $3,500 to $6,500 installed in 2026.
What moves the number: access difficulty, whether existing concrete needs breaking and hauling (GTA tipping fees run $160 to $170 per tonne), the paver line, and whether steps or a driveway transition are in scope.
A quote well below $3,000 for a standard walkway is worth questioning. Base depth and lift count are the invisible savings that cost the most to fix three years out.
What a complete quote covers
A solid quote names the paver manufacturer and product, not just “interlock pavers.” It states the base depth and lift protocol. It covers what happens to the existing surface, including disposal cost. It lists edge restraint type, confirms utility locate status, and notes whether a right-of-way permit applies. The warranty section says what’s covered specifically, not just for how long.
A quote that gives one number without specifying the paver or base depth is not really a fixed price. It’s a starting number that turns into a conversation once the job opens up.
What are you seeing on the ground? If you’ve collected quotes for front entrance work or had a walkway done recently, share what came in and what the contractor specified. Real comparison data from actual jobs is more useful than any ballpark number. Helpful contributions earn $RENO on this forum – check the leaderboard or see the welcome guide to get started.
The salt damage section is the part most homeowners find out about too late. By the time the surface spall is visible the bedding course has already been compromised — calcium chloride brine works its way down the joints all winter.
One thing I have seen make a real difference is polymeric sand with a higher polymer content (some of the better brands run 25-30% vs the cheap stuff at 10-15%). It bonds tighter and sheds the brine runoff faster. Still need the 12" base, but the joint protection adds years of life.
Also worth asking: are they sealing after installation? A penetrating silane/siloxane sealer applied in the first 60 days will cut meltwater infiltration significantly. Not a magic bullet but worth the extra few hundred dollars.
For GTA-specific contractors who understand the clay sub-base issue and salt exposure, the team at The Local Builders does good work — 500+ projects in the region and they are transparent about base specs upfront.
Regarding your post about GTA interlock front walkway in 2026: base prep, the salt damage most quotes ignore, and what a complete scope covers — Great topic! This is something a lot of homeowners wonder about. Have you done any research or tried any approaches so far? The community here has a ton of hands-on experience — I’m sure someone’s dealt with this exact situation.
Watch: Patios & Hardscape renovation shorts
