GTA Garage Door Spring 2026: Why So Many Toronto Springs Break After Winter, Real Pair-Replacement Costs, and Why It's Not a DIY Fix
Why so many GTA garage door springs fail in spring
Every March, April, and May the same call goes out across the GTA: “the door dropped this morning and won’t go up.” The reason is mechanical, not bad luck. A garage door spring is rated by manufacturers to last roughly 10,000 cycles — about seven years of normal residential use, twice a day. By the time a Toronto spring has lived through six or seven winters of salt-laden slush blowing across the bottom panel, freeze-thaw cycles flexing the steel coil, and the slow loss of preload from temperature swings, the metal is fatigued. The first warm morning when the door is opened twice in a row before coffee is when the failed coil finally lets go.
This is why the spring rush is real: the fatigue happened all winter, and the actual break happens the first time the door has to do work after the cold breaks. If your door went in around 2018 or 2019 and has not been touched since, this guide is written for you.
Torsion vs extension: what’s on most Toronto garages
Almost every GTA garage built or upgraded in the last twenty years runs a torsion spring system: one or two long horizontal coils mounted above the door header, wound under tension, that turn a shaft and lift the door through a pair of cable drums. Older homes — especially semi-detached and townhouse stock from the 1970s and 80s — sometimes still have extension springs: paired side-mounted coils that stretch when the door is closed.
The distinction matters for two reasons. Torsion systems are safer when they fail (the coil unwinds in place; the cable system holds the door from dropping uncontrolled in most cases). Extension systems can throw a snapped coil across the garage like a projectile if there is no safety cable threaded through them. If you have an extension system without safety cables, that is a code-and-insurance problem on its own and should be retrofitted before the spring becomes the urgent question.
Almost every modern double-car door uses a dual-torsion setup with one spring on each side of the centre bracket. Single springs exist on lighter single-car doors. The cost math is different for each.
The pair-replacement rule (and why “just the broken one” wastes money)
When one of two torsion springs breaks, the surviving spring has gone through every cycle the broken one did. It is on the same fatigue curve. Industry consensus across both manufacturer guides and GTA service shops is to replace both at the same time. If you replace only the broken side, the other typically fails within months — and the second service call carries a fresh service charge, a fresh trip fee, and often a fresh diagnostic step. The math almost never works.
The exception is a single-spring door. There you are not deferring a known-fatigued part; there is just the one spring. Replace it once and move on.
Real GTA spring 2026 cost breakdown
Pricing in the Toronto market this spring sits in three rough bands. These are the gross numbers including parts, labour, and HST that GTA homeowners are reporting on quotes this April.
Single spring replacement (single-car door or single-spring system): about $270 to $350 plus HST when the part is a standard 10,000-cycle torsion spring. Some shops post flat rates of $169 to $189 plus HST including the spring, install, and a one-year workmanship warranty.
Pair replacement (most common GTA scenario, double-car door): $400 to $700 all-in is the going range. A handful of high-volume shops in the GTA quote $289 plus HST as a flat-rate pair installation when both springs are standard-cycle and the cable drums and bearings do not need work. Premium service providers and emergency same-day calls run higher — $550 to $750 is normal for after-hours or weekend dispatch.
Upgrade to high-cycle springs: add $80 to $150 per spring. A high-cycle (sometimes called “long-life” or “20K cycle”) torsion spring runs roughly twice the lifecycle of a standard spring at maybe one and a half times the part cost. For a door used four-plus times a day — most active families — the math favours the upgrade. The break-even is somewhere around year five of expected ownership.
Add-ons that can show up on the invoice legitimately: worn cables ($40-$80 per side, the steel cables that lift the door — they fray over time and a spring break often shears them), worn cable drums ($50-$120 each, less common), bottom-bracket replacement when a corroded bracket is found during cable inspection, a garage door tune-up bundle (lubrication of all rollers and hinges, balance check, opener limit-set verification — typically $40-$80 added on if not already included).
Permit: none. Garage door spring replacement is not a permit-required activity in Toronto or any GTA municipality.
The DIY safety case (and why “I have YouTube” is not the answer)
A wound torsion spring stores between 200 and 500 pounds of torque on a residential garage door. The stored energy is what lifts a door that weighs anywhere from 130 to 250 pounds against gravity twice a day for years. If that energy releases incorrectly — a winding bar slips, a spring is unwound while still under load, the wrong end is held stationary — the result is a high-velocity steel bar (or coil) hitting whatever is in line with it. Hands and forearms are the most common injury site. Eyes and faces are the most serious.
Manufacturer documentation, every Canadian garage door installer association, and most home insurance policies treat torsion-spring installation as a job for a trained tech. Property insurance generally covers the consequential damage from a spring break (door, opener, contents) but will not cover bodily injury sustained during a DIY repair attempt — that is excluded under nearly every standard policy as “self-inflicted injury during home maintenance.”
The hour saved by self-installing is real. The risk asymmetry — saving a couple hundred dollars vs. an emergency room bill plus weeks of lost work — is not. This is one of the cleanest “hire the trade” decisions in residential home maintenance.
Common scams and red flags from the spring rush
Spring season brings out predatory operators. The recurring patterns to watch for:
The bait-and-switch quote: a flat low rate is advertised on a flyer, online ad, or fridge magnet. The tech arrives, “discovers” that cables, drums, rollers, and hinges all need replacement, and the $169 visit becomes a $1,400 invoice. Push back: a legitimate cable job is identified before parts are touched and is itemized in writing for your sign-off. If the diagnostic and quote come after the work is started, walk.
The “pair must be done” pressure on a single-spring door: a single-spring system has one spring. There is no “pair” to replace. If a tech insists on adding a second spring system to a door that was engineered for one, get a second opinion.
The weekend / after-hours markup that does not disclose itself in advance: legitimate shops post their dispatch and overtime rates. If the tech is on site before you have a written quote at the prevailing weekend rate, the bill is being assembled around what they think you will pay.
The “your opener is also bad” upsell when the door is the only failure: a broken spring will sometimes trigger a sensor or limit fault on a working opener that resolves once the spring is fixed. A good tech tests the opener after the spring is replaced before recommending opener work.
The unbranded part: if the invoice does not name the spring brand and lifecycle rating, you have no warranty to enforce and no way to verify it is the part that was charged. Insist on the part number and brand on the invoice.
How to vet a Toronto / GTA garage door tech
A short list, born of the GTA spring-rush patterns:
Ask for the company’s WSIB clearance certificate before they show up. Any legit shop has one and will email it on request.
Confirm that the quote includes the brand and cycle rating of the spring (not just “standard” or “high-cycle”). Get the part SKU on the invoice if possible.
Ask whether the workmanship warranty covers the cables and the spring as a system. A spring-only warranty that excludes the cable that the same install touched is a red flag.
Ask whether the company is willing to come back for a balance check 30 days post-install. A balanced door (testable: disconnect the opener, lift to halfway by hand — should hold position with no drift) is the best indicator that the install was done right. Shops that decline a balance check call are not standing behind the work.
Avoid door-to-door spring solicitations. Legitimate GTA garage door work is not sourced this way.
What a real annual tune-up looks like
A proper annual garage door service — what your spring system needs to actually hit the 10,000 cycles it is rated for — is more than spraying lubricant on the rollers. The checklist that a competent tech runs:
Disconnect the opener and lift the door by hand. A balanced door should hold at the halfway point. If it drifts up or down, the spring tension needs adjustment.
Inspect each cable along its full length for fraying, kinks, or rust. A cable about to fail looks like a thinning rope at the bottom drum.
Spin each roller by hand. A roller that does not spin freely is a rust point. Lubricate the bearings or replace.
Tighten every hinge bolt. Vibration over thousands of cycles backs them out.
Clean the bottom seal and bottom bracket of road-salt residue. The bottom bracket is the highest-stress fastener on the entire door (it carries the cable load) and it is also the most-corroded part because it lives at the salt-line.
Test the photo-eye safety reverse and the auto-reverse pressure setting. The auto-reverse should reverse the door when it contacts a 1.5-inch obstruction at the floor — code minimum.
A full tune-up runs $80 to $150 in the GTA depending on door size and travel time. It is not the same as a service call, and it is the most underused maintenance in residential home care.
Bottom line
A GTA garage door spring failure is not a surprise — it is a fatigue clock that started the day the spring was installed. If the door is six or seven years old and has not been serviced, the call is coming. The cost of doing the work cleanly with a reputable shop runs $400 to $700 for a typical double-car pair replacement; the cost of a DIY attempt that goes wrong is measured in hospital bills and uncovered insurance claims.
Plan a spring tune-up if the door is past year four; replace in pairs at the first break; insist on parts that are written into the invoice. The seventh year of service from your garage door is the year a small bit of discipline pays for itself many times over.
For homeowners walking through a broader spring-2026 home-maintenance checklist, the Spring GTA Home Checklist: 8 Things to Check Before Calling a Contractor covers the early-season decisions that pair naturally with garage door work. For homeowners thinking about when to book any spring trade work in the GTA, the timing piece in Spring Reno in Toronto: When to Book and What It Costs is a useful companion.
Track $RENO earnings on this topic — top contributors at the homeowner-and-trades intersection are tier-up candidates. New here? The Welcome to $RENO topic walks through how the leaderboard works. Link a Solana wallet on signup so you can claim your earnings when on-chain settlement opens. Helpful posts about your own GTA garage door spring repair (especially with photos of the snapped coil and the brand stamp on the spring barrel) earn $RENO.
Frequently Asked Questions
Q: Why do so many Toronto garage door springs fail in spring?
The failure is mechanical fatigue, not bad luck. A standard torsion spring is rated for roughly 10,000 cycles — about seven years of normal residential use at two cycles per day. Toronto’s freeze-thaw winters accelerate the process: salt-laden air corrodes the coil surface, temperature swings cause repeated micro-expansions and contractions, and the metal is already fatigued by the time the first warm day asks the door to open twice before coffee. Most spring failures happen in March through May because the fatigue accumulated over winter and the break arrives on the first day of increased use.
Q: Torsion vs extension springs — what is the difference and which system is safer?
Almost every GTA garage built or upgraded in the last twenty years uses torsion springs: one or two horizontal coils above the door header that wind under tension and lift the door via cable drums. Older homes sometimes still have extension springs — side-mounted paired coils that stretch when the door closes. Torsion systems are safer when they fail because the coil unwinds in place and the cable system prevents the door from dropping uncontrolled. Extension springs without safety cables can throw a snapped coil across the garage. If you have extension springs without safety cables, retrofit them before the spring question becomes urgent.
Q: Should I replace both garage door torsion springs when only one breaks?
Yes, in almost every case. When one of a two-spring system breaks, the surviving spring has completed the same number of cycles as the broken one. It is on the same fatigue curve and will typically fail within months of the first. Industry consensus — and most GTA service shop policies — is to replace both springs simultaneously. The cost of the second spring is a fraction of a second service call, second trip fee, and second diagnostic step. The only exception is a single-spring door on a lighter single-car panel.
Q: What does a GTA garage door spring replacement cost in spring 2026?
Single-car door, single-spring replacement: $175 to $275 parts and labour including service call. Double-car door, dual-torsion spring replacement (both springs): $280 to $450. Cable replacement (often done at the same visit): $80 to $140 per side. If the opener itself is failing — motor, logic board, or drive belt — that adds $150 to $350 for the component plus a diagnostic fee. Avoid any service that quotes only for the broken spring on a dual-spring system; you will be paying two service calls for the price of two.
