GTA Deck Replacement Spring 2026: Costs by Material, OBC Permit Rules, and Best Booking Window
Spring is the loudest season for deck quotes in the GTA. Homeowners pull the patio furniture out, see soft boards, popped fasteners, and rust streaks across the joist hangers, and start calling builders. The quotes come back ranging from “we can squeeze you in next month” to “we are booked through August” with prices that can vary by 40% on the same square footage. This thread is for anyone trying to make sense of those quotes for spring 2026 — what each material actually costs in the GTA right now, where the Ontario Building Code rules genuinely matter, what spring timing buys you (and what it does not), and the line items that separate a 25-year deck from a 7-year one.
Real GTA spring 2026 cost bands by material
Quotes in Toronto and the surrounding municipalities for spring 2026 are landing in a fairly tight range across reputable builders, with the spread driven mostly by deck height, footing depth, demolition scope, and railing type — not the brand of the boards.
A 200 square foot pressure-treated deck, ground level or near it, no demo, basic post-and-rail wood guard, is landing in the $6,000 to $9,000 range fully installed. The same 200 square foot footprint built in cedar runs $8,000 to $11,500. Composite at the same footprint is $10,000 to $16,000 depending on which line of board (entry-level capped composite vs. premium tropical-look). PVC is generally $12,000 to $18,000 at 200 square feet.
Step up to a 300 square foot deck with railings, stairs, and demolition of the old structure included, and the per-square-foot costs land in the $60 range for pressure-treated (around $18,000), $70 for cedar (around $21,000), and $80-plus for mid-to-high-tier composite (around $24,000). PVC at the high end of finishes can push 300 square feet past $28,000 once you add picture-framing, hidden fasteners, and aluminum or glass guards.
A more useful frame for budgeting: per square foot, $25-$35 for pressure-treated, $30-$45 for cedar, $42-$75 for composite, $50-$70 for PVC as a base material range. The all-in installed cost ends up roughly double the material cost once you add labour, footings, demo, fasteners, framing, railings, stairs, and permits. That is why a “materials look cheap” quote can still come out high on the total.
Where the OBC rules actually matter
The Ontario Building Code 2024 (still in effect through most of 2026 with the 2025 amendments) governs deck construction, and there are three places where the rule matters more than homeowners realize.
Permits. Any deck more than 600 mm (just under 2 feet) above grade requires a building permit in most Ontario municipalities, including Toronto, Mississauga, Brampton, Markham, Vaughan, Oakville, and Hamilton. Below that threshold, a permit is often not required, but attachment to the house, proximity to property lines, and total area can still trigger one — confirm with your municipality before signing a contract. A contractor who tells you “we never pull permits, the city does not check” is telling you the city does not check today, not when you sell the house and the buyer’s home inspector flags an unpermitted attached structure.
Footings and frost line. Footings must extend below the frost line. For southern Ontario including Toronto, that is 1.2 metres (4 feet) below finished grade. Anything shallower will lift in winter and the joists will crown — common on older decks built with 24-inch sonotubes and a “we will see how it goes” approach. Helical piles are increasingly popular as an alternative because they remove the dig-and-pour weather window from the schedule, but they are not universally cheaper — expect $250 to $400 per pile installed.
Guards. Guard height depends on deck elevation. If any portion of the walking surface is more than 1,800 mm (5 ft 11 in) above finished grade, the entire railing must be at least 1,070 mm (42 in) high. If the walking surface is at or below that 1,800 mm threshold, 900 mm (36 in) guards are permitted. Openings in guards must prevent passage of a 100 mm (4 in) sphere — the toddler-head rule — which is what kills most “modern horizontal cable rail” inspections that did not specify a tight enough cable spacing. The Code also prohibits horizontal elements that act as footholds between 140 mm and 900 mm above the deck surface — no horizontal slats a child can climb. Aluminum picket guards are the path of least friction; tempered glass and vertical cable systems work but require specifying the right installer.
What spring booking actually gets you (and what it does not)
The April-to-June quote rush in the GTA pushes good builders to 6-to-10 week lead times. The honest pattern: book in March-April for late-spring or early-summer install, expect to pay full sticker, and lock material on order at signing. Booking in October or November for a winter or following-spring install can save 5-10% because builders are filling the slow shoulder season — that is real money on a $20,000 deck. Toronto weather usually allows builds through late November in most years; pressure-treated lumber can be installed in cold weather without issue, composite boards are slightly more sensitive to the substructure being out-of-plane in temperature swings.
What spring booking does not buy you: cheaper materials. Material prices in spring 2026 are stable to slightly up from 2025, with pressure-treated lumber back in a softer range after last summer’s tariff scare and composite boards holding pricing as supply chains re-stabilized. The “lock now or lumber will jump” pitch is not accurate for spring 2026 right now — but it may become accurate again by late June if the U.S.–Canada lumber tariff situation reignites mid-summer. Lumber pricing was discussed in more detail in Lumber Is Up 5% This Spring: What Does It Mean for Your GTA Reno Budget for anyone tracking that thread.
Three things in a quote almost always separate a 7-year deck from a 25-year one. If your contractor cannot answer them in writing, the quote is incomplete.
Footing spec. “Footings to code” is not an answer — code allows several methods, and the right one depends on soil and load. The quote should name sonotube diameter (8" or 10"), pour depth (1.2 m below grade in Toronto), and concrete spec, OR helical pile model, length, and torque rating. If the quote reads “concrete piers” with no depth, you are paying for an unknown.
Joist hanger and fastener spec. Galvanized hangers (G185 minimum) and stainless or hot-dip galvanized fasteners — never electroplated. Pressure-treated lumber chemistry is corrosive; the wrong fastener turns to rust within five winters. Composite-board hidden fastener systems (Camo, Cortex, Trex Hideaway) have specific install schedules that determine whether the warranty stays valid.
Demo and waste haul. “Demo included” should specify whether it is full demo of the existing structure including footings, partial demo to the joists, or surface-board removal only. The quote should also include the dump fees and bins — a 10-yard bin in Toronto runs $400-$550 for an old-deck haul, and that line item disappears from cheaper quotes by being silently excluded.
The 2025 OBC also tightened up energy and structural details on attached decks where a ledger board contacts the house — flashing detail, ledger fastener pattern, and clearance to siding/cladding. For attached decks against an older Toronto stock house with stucco or board-and-batten cladding, a contractor who specifies the flashing membrane (peel-and-stick at the ledger) and the fastener pattern (lag bolts on a ledger spec, not deck screws) is doing the right thing.
When the answer is rebuild, not repair
If joists are sound and only boards are tired, a re-deck (boards and railings only, framing kept) runs about 40-55% of full replacement and is a clean spring weekend project for any reputable builder. If joists are sagging, hangers are rusted through, or footings have heaved, the answer is full rebuild — patching new boards onto compromised framing fails inside two seasons and the warranty is void.
For homeowners deciding between a deck rebuild and switching to a hardscape patio, the Deck vs. Interlock vs. Flagstone: What GTA Homeowners Should Know thread is the better starting point.
Track $RENO earnings on this topic — top contributors at the homeowner-and-trades intersection are tier-up candidates. Helpful answers, real photos of the install, and post-mortems on what went wrong are what move the needle. Newer earners can link a Solana wallet on signup to claim earnings when on-chain settlement opens — see Welcome to $RENO — Quests, Rewards, Leaderboard for the tier ladder and the quest catalogue.
Frequently Asked Questions
Q: What are real GTA deck replacement costs by material in spring 2026?
Per square foot installed: $25 to $35 for pressure-treated, $30 to $45 for cedar, $42 to $75 for composite, $50 to $70 for PVC. The all-in installed cost runs roughly double the material cost once you add labour, footings, demolition, fasteners, framing, railings, stairs, and permits. A 200 sq ft pressure-treated deck runs $6,000 to $9,000; the same footprint in cedar runs $8,000 to $11,500; composite at 200 sq ft is $10,000 to $16,000 depending on the board line.
Q: Does a deck in Toronto or the GTA require a building permit?
Any deck more than 600 mm (just under 2 feet) above grade requires a building permit in most Ontario municipalities including Toronto, Mississauga, Brampton, Markham, Vaughan, Oakville, and Hamilton. Below that threshold a permit is often not required, but attachment to the house, proximity to property lines, and total deck area can still trigger permit requirements. Confirm with your local building department before signing a contract. A contractor who tells you permits are never required is either uninformed or hoping you do not check.
Q: What material makes the most sense for a GTA deck in 2026?
For a deck that will be in heavy daily use for 25 or more years with minimal maintenance, mid-to-upper-tier capped composite is the clearest choice: it does not rot, warp, splinter, or require annual staining, and the colour holds in Toronto’s UV and freeze-thaw exposure better than wood-based materials. Cedar is the best choice if you value natural aesthetics and are committed to annual or biennial maintenance. Pressure-treated is the right call on a tight budget or when the deck is a stepping stone before a larger outdoor project. PVC is competitive with composite on performance but limited in realistic colour and profile options at most price points.
Q: What separates a 25-year deck from a 7-year deck at the contractor level?
Three things determine longevity more than material choice: footing depth (below the frost line — minimum 1.2 metres in the GTA; shallower footings heave and crack within a few winters), joist hanger quality (galvanized vs standard steel; galvanized hardware resists the corrosion that destroys standard hangers under treated lumber), and ventilation under the deck boards (proper gap between boards and good air circulation underneath prevents moisture trap and rot in any wood-based material). A quote that does not specify footing depth or hardware spec is missing the items that actually determine how long the deck lasts.
