Exterior Painting Our 1960s Toronto Brick + Stucco Home - Full Project Breakdown
Our 1963 Toronto semi has the classic combination: brick on the front, stucco on the sides and back. Repainted the stucco and all trim last summer. Full breakdown.
The Condition Before
Stucco: last painted approximately 2008 (16 years prior). Significant chalking - could rub white off on fingers. Small hairline cracks throughout. Two larger cracks (1/4"+) at window corners.
Trim: peeling at soffit on north side, likely moisture infiltration from a gutter issue we had fixed the previous year.
Contractor Selection
Got 4 quotes ranging from $4,200 to $7,800. Chose the $5,900 quote - not the cheapest, but they were the only ones who specifically mentioned stucco patching as part of their scope.
Work Done
Week 1 prep:
  • Pressure washed all stucco surfaces (50-foot sides + back)
  • Scraped and sanded all peeling trim
  • Applied elastomeric stucco patch to all cracks, feathered smooth
  • Replaced two sections of rotted fascia
  • Caulked all window perimeters and trim joints
Week 1-2 painting:
  • Prime coat on all patched areas and bare wood
  • 2 coats Benjamin Moore Aura Exterior on stucco (Regal Select used on trim)
  • Colour: stucco in Revere Pewter (BM HC-172), trim in Chantilly Lace white
Total Cost
Painting: $5,900
Fascia replacement (not in original scope): $380
Total: $6,280
Two Years Later
No peeling, no cracking at repaired areas, still looks fresh. The elastomeric patch on the stucco cracks has held perfectly.
What I Would Do Differently
Nothing major. The prep week was worth every dollar - the houses nearby that were painted the same summer and skipped prep are already showing hairline cracking through the paint at the same spots.
For exterior painting contractor recommendations in the GTA visit home.renovation.reviews.
Watch: Painting renovation shorts
