Deck and Pergola Permits in the GTA - What Requires a Permit in 2026
Getting conflicting info from neighbours about permit requirements for my planned deck + pergola project. Spent a few hours researching across several GTA municipality websites - here is what I found.
The Provincial Baseline
Ontario Building Code says structures under 10 sq m (107 sq ft) on a 1-2 storey residence may be exempt from permits. But municipalities can be more restrictive than this provincial minimum.
What I Found Per Municipality
Toronto: Decks over 0.6m (24") above grade require a building permit regardless of size. Freestanding structures under 10 sq m may be exempt. Attached structures (pergola attached to house) require permit.
Mississauga: Same threshold - decks over 600mm need permit. Structures attached to house need permit.
Brampton: Decks over 300mm (1 foot) above grade require permit - more restrictive than provincial baseline.
Markham: Permit required for decks above 600mm. All structures attached to house require permit.
Setbacks: Critical Even for No-Permit Structures
Even if your structure does not require a permit, you must comply with zoning setbacks. Rear yard setbacks are typically 1.2m-3m from the property line in GTA suburbs. Side yard setbacks are often tighter. Build inside your setbacks or get a zoning variance.
My Situation
12x16 ft deck (1.8m above grade at highest point) + attached pergola. This requires a permit in every GTA municipality. Budget: $300-$700 for permits, 3-6 weeks wait for approval.
Advice
Do not skip permits on deck projects. Insurance companies are denying claims on unpermitted structures. Re-sale inspectors flag them. The cost of retroactive permits or demolition is far worse than doing it right the first time.
Anyone know the current wait times for deck permits in Brampton or Hamilton area?
