Calgary basement development quote — what it should include before you sign
Seeing a lot of quote questions here, mostly GTA. Adding a Calgary angle since the permit side works a bit differently out west.
If you’ve got a basement development quote in Calgary, check that it clearly covers:
  • Permits — who’s pulling them and whether the cost is included. The City of Calgary needs a building permit for basement development, plus separate electrical and plumbing permits. If a quote says nothing about permits, ask.
  • Egress windows — if the plan has a bedroom, it needs a proper egress window. Cutting the foundation and the window well are a big line item, so it shouldn’t be hidden or missing.
  • Moisture and insulation — vapour barrier, insulation type and any waterproofing written out, not just “framing and drywall.”
  • Mechanical — is HVAC ducting extended to the new rooms? Is the electrical panel big enough for the added circuits?
  • Allowances — flooring, fixtures and cabinets listed as allowances can make a cheap quote end up expensive. Ask for the actual amounts.
  • Payment schedule — a big deposit up front with vague milestones is a red flag.
Easiest test: get two or three quotes and line them up item by item. The cheapest one is usually missing something, not actually cheaper.
I work with a Calgary basement renovation team (calgarybasementrenovation.ca), so happy to answer Calgary-specific questions here, no strings attached.
