Black fittings vs silver fittings after regular use
I used to think fittings were just small details in a house, but after seeing different homes, I realized they affect both look and maintenance over time.
Black fittings usually give a modern and bold look. They stand out and make bathrooms or kitchens feel more stylish. At the beginning, they look very clean and sharp.
But after regular use, I noticed something. Black fittings can show water marks, soap stains, and scratches more clearly, especially in areas that are cleaned often. If the finish is not strong, it can start to fade or chip over time.
Silver fittings feel more traditional, but they are very practical. They blend easily with most designs and do not stand out too much. One thing I like about silver is that scratches and water marks are less visible compared to black.
They also feel easier to maintain in the long run because they do not lose their look quickly.
I think black fittings are better for style and modern design, while silver fittings are better for durability and easy maintenance.
Both work well, but they give very different experiences after some time of daily use.
Black fittings usually look cleaner at first, but over time they tend to show wear, water marks, and can lose that fresh look faster than silver ones. Silver is more forgiving for daily use, even if it shows a few spots.
I tell you the picture says it all friend, let’s keep up the good work
I do prefer using the black fitting more than this siliver one
