Benmiller Construction: Basements & Spray Foam, Goderich ON
Benmiller Construction & Insulation — Basement & Spray Foam Specialists in Goderich, ON
Benmiller Construction & Insulation operates out of 81175 Grist Mill Line just outside Goderich, focusing on the hidden layer of home performance — insulation, moisture control, and basement envelope work. Their service mix pairs building-envelope trades (“Basement Boss” for below-grade solutions, “Healthy Home Solutions” for indoor air and moisture) under one roof, which is rare in smaller-market Huron County.
Services
  • Spray foam (closed-cell) and blow-in attic insulation
  • Basement waterproofing, sump pump sealing, and interior wall liners
  • Drainage tile and exterior moisture-intrusion repair
  • General construction scope adjacent to envelope and below-grade work
Service Area
Goderich, Clinton, Bayfield, Grand Bend, Kincardine, and rural Huron & Lambton County properties within an hour’s drive.
Insulation-and-basement specialists are an underrepresented category in directory listings — most homeowners search “contractor” first and only discover they need a spray-foam or waterproofing crew once a GC tells them. Surfacing Benmiller as a distinct envelope / moisture shop helps readers find the right trade the first time, especially owners of older Lake Huron–shore homes dealing with chronic basement damp.
