When Temporary fixes become permanent
We all have at least one “temporary” fix at home that has somehow ended up becoming permanent for years.
This starts from procrastination, that quick patch, or move a chair there “for now,” use tape temporarily, leave a box in a corner for a few days, or delay finishing one small renovation detail until later.
Then somehow it takes months years and the fix is still there.
The interesting part is how quickly a lot of people mentally adapt to unfinished things inside their homes. In the beginning, the issue is obvious and annoying every single day.
But after a while, their brain slowly starts treating it as a normal background scenery.
Also, temporary fixes are psychologically easier because they remove urgency. When that fix makes the problem “good enough,” the immediate pressure to properly finish it is gone.
But at the same time, those little unfinished things quietly create small mental stress. Seeing incomplete projects repeatedly can make a home feel chaotic even when everything else looks fine.
When you finally fix that old “temporary” problem the satisfaction is weird because you realize how long you were mentally carrying something you stopped consciously noticing.
So accurate :sob: “Temporary” fixes somehow become part of the house personality. And the moment you finally repair them properly, you instantly wonder why you waited so long in the first place.
Temporary fixes have a funny way of staying around much longer than people originally planned :sweat_smile: Sometimes the quick solution just becomes part of the house for years.
There are sometimes when u fixed something and it turns out to blend in with the house
For me most time I prefer temporary fixing because on the process you will give more effort to it when fixing
