What's Your Biggest Home Renovation Win of 2026 So Far?
We’re already into April and I know a lot of you have been deep in projects. Whether it was a full kitchen gut, a quick deck build, or finally finishing that basement you started three years ago — I want to hear about your wins.
Here’s mine: I finally replaced the original 1980s windows in our two-story colonial. Went with triple-pane low-E glass and the difference in both noise reduction and energy bills has been night and day. Our heating costs dropped noticeably even just through the tail end of winter.
So let’s hear it — what renovation project are you most proud of this year? Bonus points if you’ve got before-and-after photos to share.
And if you’re still in the planning phase, tell us what you’re working toward. Sometimes the best advice comes from people who just finished what you’re about to start.
Triple-pane + low-E is one of those upgrades that pays you back in ways you don’t see on a spreadsheet. The noise drop alone is worth it if you’re anywhere near a busy street — we’ve retrofitted a lot of older Toronto houses where the homeowner thought they needed insulation in the walls, and it turned out the walls were fine; it was just ancient single-pane wood sashes leaking everything.
I’ll bite — my 2026 win so far is nothing glamorous, it’s a basement waterproofing job we wrapped up on an East York semi in March. Homeowners had been dealing with seepage every spring for about a decade and had been quoted everything from a full interior dig-up to a chemical injection. What actually solved it was a combination of exterior excavation on two walls, a proper membrane with dimple board, a new perimeter weeper tied into a sump, and regrading the lot away from the foundation. Not sexy. But four weeks of rain since and that basement is bone dry for probably the first time since the 70s.
The reason I’m calling it a “win” is because the homeowners almost went with the cheapest quote — a $3K injection job that would’ve been a band-aid and probably failed again within two years. I’ve seen that exact sequence at least twenty times. Spending the money once on the right solution is almost always cheaper than the three “fixes” that come before it.
If anyone here is thinking about basement moisture this spring — post details, I’ll tell you honestly whether it’s a quick fix or not. Most of it comes down to whether the water is coming through the wall, up through the floor slab, or both.
And curious to hear everyone else’s wins. Extra points for “I thought it would be terrible and it turned out great” stories — those are the most useful for everyone reading.
Piggybacking on the East York basement story — something I’ve noticed this spring is that the homeowners who are having the biggest “wins” in 2026 aren’t the ones doing the flashiest projects. They’re the ones who finally fixed whatever they’d been ignoring for five-plus years.
A few 2026 wins I’ve watched happen in the GTA this season that were not even on the homeowners’ radar when the year started:
  • Replacing a 30-year-old asphalt driveway with interlock and actually fixing the grading at the same time — turned out to be the cheapest basement waterproofing job they ever did, because half the seepage was surface water sheeting toward the foundation.
  • Pulling an old, struggling electrical panel and going to 200A while rough-ins were open during a kitchen reno. Saves a ton vs. doing it as a standalone project two years later.
  • Swapping a rusted aluminum soffit/fascia/eavestrough system on an older Etobicoke bungalow. The homeowners thought they had an insulation problem. It was actually 40 years of water getting behind the fascia and rotting the soffit cavity, which then dumped into the attic.
If you’re still thinking about what your 2026 “win” should be, a practical question: what’s the one thing in your house that would be way worse to fix if you waited until it failed versus dealing with it on your terms? That’s almost always the right next project.
For anyone curious about the scope of stuff we actually handle — kitchens and baths get a lot of the glamour shots, but waterproofing, interlock and flagstone, aluminum work, and exterior grading are where most of the “invisible win” work happens. Full rundown on lfbuilders.ca if helpful.
Keep the wins coming — spring’s the right time to hear these.
Saw one this week that I keep thinking about. Older couple in Mimico, 1950s bungalow. Their “win” was not a project in the usual sense. It was finally finishing the permit paperwork on a basement apartment their son had started during the pandemic. Walls were up, wiring done, but no inspection had ever been booked so the whole thing sat unusable for four years.
They paid a few hundred for a compliance review, got an electrician back in for a corrective visit, booked Toronto Building, and passed inspection at the end of March. Suddenly they have a legal secondary suite they can rent or move into themselves, and the house reassessed noticeably higher for the same reason. Zero new construction this year, just paperwork they had been avoiding.
That is the 2026 pattern I keep seeing. The real wins are not new projects, they are closing out old ones. Unfinished decks finally getting the handrail up to code. Kitchens from 2022 getting the one backsplash section that never got done. Warranty claims that homeowners never filed because “it was too late” (most of the time it is not).
Anyone else sitting on a half-finished project from a previous year? Sometimes a quick consult on what is actually stopping you from closing it out is the real win. Drop what is stuck in the comments. Happy to point you at which trade you probably need to call.
Coming back to this thread before the week closes.
We have had a busy forum week, permits, budget shocks, interlock failures, a lot of good technical back-and-forth. But this one has been quieter than it deserves.
If you have had a renovation win this year, even a small one, this is the place to drop it. Fixed a leak that has been dripping since before COVID? Replaced a window and actually felt the difference on a cold night? Finally tackled the front walk that has been embarrassing you every spring? That counts. It does not have to be a full gut reno.
Tagging some regulars who have been active this week: @Defizyn @Kizzy1 @CRYPTOSAVAGE06 @Jakurasmith. Would genuinely love to see something from any of you in this thread.
One more note while I have this open: Samm Simon from our team is currently running 251 km to raise money for cancer research, specifically the London Health Sciences Cancer Program, Stratford General ER, and Wellspring Stratford. Spring project completions and causes that matter tend to feel like the same energy to me. If you want to follow along or contribute, the GoFundMe link is at sammsimon.ca.
Drop a win. Big or small.
Watch: Roofing renovation shorts
