What it actually costs to pull a permit in the GTA in 2026
If you’ve ever priced out a renovation and had the contractor say “add 10-15% for permits,” you’ve probably wondered what that actually means in dollars. In 2026 the answer has gotten clearer — and a bit more expensive.
The Toronto base formula
The City of Toronto charges a base fee of $4,380 plus $16.60 per square metre of affected floor area. On top of that, every hour of plan examination and inspection is billed at $92.79. For a mid-sized addition or whole-home reno touching 100 sqm of space, you’re looking at $6,040+ in permit fees before a single inspector walks through the door.
For comparison, Mississauga and Brampton run different schedules but land in the same ballpark — typically $200 to $800 for smaller scopes and scaling up from there.
The permits most homeowners forget
The main building permit covers structure. But the moment you touch mechanical, electrical, or plumbing on a project valued over $5,000, each trade needs its own permit. In 2026 that’s $445 to $1,020 per trade permit in Toronto. A kitchen gut-reno that hits all three trades — electrical panel upgrade, new plumbing rough-in, HVAC change — can easily add $2,000+ in permit fees beyond the building permit itself.
What triggers a permit in the first place
This is the part that surprises a lot of people. In Ontario you need a permit for:
  • Structural changes (removing walls, adding beams)
  • Additions of any size
  • New windows or doors that change the rough opening
  • Basement underpinning or waterproofing that touches the foundation
  • Finished basements (in most municipalities)
  • Secondary suites and garden suites
  • Decks above 600mm from grade
You do NOT need a permit for cosmetic work — flooring, painting, kitchen cabinet swaps that don’t touch structure or mechanicals. But the line between “cosmetic” and “structural” gets blurry fast once you start opening walls.
The real cost of skipping the permit
Some homeowners skip permits to save time and money. In 2026 this is a riskier calculation than it used to be:
  1. Insurance won’t cover unpermitted work. If a fire starts in a wall you renovated without an electrical permit, your claim is at serious risk.
  2. Sale complications. Buyers’ home inspectors and lawyers pull permit history. Unpermitted work gets flagged, kills deals, or forces retroactive permits — which can mean opening walls.
  3. The basement flood subsidy. Toronto’s new $6,650 subsidy for backwater valves and sump pumps (effective May 1, 2026) requires proof of proper installation — which implies a permit. No permit, no rebate.
How to budget for it
A realistic permit line item for common GTA projects in 2026:
  • Basement finish (800 sqft): $1,500 - $3,000
  • Kitchen reno with electrical + plumbing: $2,500 - $4,500
  • Addition (200 sqft): $5,000 - $9,000+
  • Garden suite or secondary unit: $8,000 - $15,000+ (includes planning fees)
Always get your contractor to pull the permit, and get the permit number in writing before they start. In Ontario the permit holder is responsible for inspection sign-offs — if your contractor pulls it and disappears, you inherit that liability.
Has anyone had their permit timeline or cost surprise them this season? The timelines have improved in some municipalities but are still stretching to 10-20 business days in Toronto for residential. Worth factoring into your spring start date.
L.F Builders has been navigating GTA permits for over 50 years — get a quote or browse contractor discussions at home.renovation.reviews
Frequently Asked Questions
How much does a building permit cost in Toronto in 2026?
The City of Toronto charges a base fee of $4,380 plus $16.60 per square metre of affected floor area, with plan examination and inspection billed at $92.79 per hour. On a project touching 100 sqm, expect $6,040 or more before any inspector visits. Trade permits (electrical, plumbing, mechanical) are $445–$1,020 each, on top of the building permit.
What renovations require a building permit in Ontario?
Structural changes, additions, new windows or doors that change the rough opening, basement underpinning, finished basements in most municipalities, secondary and garden suites, and decks above 600mm from grade. Cosmetic work — flooring, painting, cabinet swaps that don’t touch structure or mechanicals — generally does not require a permit.
What happens if I do unpermitted renovation work in Ontario?
Insurance may not cover unpermitted work in a claim. During a home sale, buyers’ inspectors and lawyers flag permit history — unpermitted work can kill deals or force costly retroactive permits. Toronto’s 2026 basement flood subsidy of $6,650 also requires proof of proper permitted installation.
How long do permit approvals take in the GTA in 2026?
Toronto residential permits are currently running 10–20 business days for most scopes. Factor this into your project start date — work cannot legally begin before permit issuance, and contractor schedules cannot legally move forward without it.
LF Builders also supports Samm Simon’s 251 km charity run for cancer research — every kilometre raises funds for cancer research. For more permit and renovation guides, see home.renovation.reviews.
For more renovation guides and how-tos, visit the LF Builders renovation blog.
One thing worth flagging for anyone reading this right now: the City of Toronto launched a $6,650 subsidy for basement flood protection — backwater valves and sump pump installations — effective May 1, 2026. The catch is it requires proof of proper installation, which in practice means the work was done to permit standard.
So if you have been sitting on a quote for basement waterproofing or a backwater valve, the timing math has changed. A permit that used to feel like friction is now the thing that unlocks a meaningful rebate on a $6,000+ job.
The other thing that trips people up on permit timelines: Toronto is currently running 10-20 business days on residential applications. If you are hoping to start waterproofing work before the first heavy spring rain hits, the window for a smooth permit is closing fast. Apply now, not after you have already booked the contractor.
One practical note if you are filing your own application: make sure you are using the current City of Toronto form. The application was updated on February 16, 2026 — the old version gets rejected on submission, not flagged for revision, just rejected. That detail alone can add three weeks to your timeline without anyone telling you why.
For a full breakdown of which GTA projects trigger permits and which trade permits you need beyond the base building permit, the permit cost breakdown above covers it — and the Most Commonly Asked Questions thread is a good first stop if you are newer to the forum.
