Volunteering to fix up a charity home kitchen was an absolute reality check
A local community shelter needed some urgent contractor work done on their main kitchen prep area before their seasonal inspection, so I offered to head down there for a weekend to handle the demo and tile work. The facility manager told me it just needed some fresh backing board and a clean layout of basic ceramic tiles behind the heavy industrial ovens. Honestly, dealing with commercial grade grease buildup and ancient wall studs turned the quick volunteer shift into a massive, exhausting grind.
The nightmare started the second the old plastic wall panels came down. Decades of heavy cooking steam and hidden leaks had completely rotted out the bottom framing timbers behind the stoves. You couldn’t even drive a drywall screw into the wood because the studs had turned into absolute mush. I had to pivot the entire plan immediately, clear away the damp insulation, and sister brand new studs directly to the old frame just to create a solid structural wall that could actually support the weight of the new tile sheets.
Then came the absolute worst part, scrubbing the surrounding brickwork to get the mortar to stick. Commercial kitchens accumulate a thick, stubborn layer of invisible grease that standard soap won’t even touch. I spent three straight hours hunched over in a hot, unventilated room with a heavy wire brush and an industrial degreaser, scraping the walls until my wrists were totally numb. Every splash of the chemical cleaner felt like liquid fire on the small cuts on my hands, and the fumes were so strong I had to keep stepping outside just to catch a breath of clean air.
We finally managed to get the heavy cement backer boards up and laid down a clean, solid row of white commercial tiles right before the weekend deadline hit. The shelter kitchen looks a thousand times brighter now, and the inspectors are going to be completely thrilled with the sanitary layout. The shelter staff actually made a massive batch of fresh chili for everyone who helped out, which was an amazing way to wind down after spending forty eight hours straight covered in plaster dust and grease.
Behind every clean, functional space is unseen hard labor, problem solving, and resilience under pressure that most people never notice.
This apart from the stress is a great thing to do, just like Samm Simon’s 251 KM run against cancer, you people have fixed a charity home kitchen and they’ll remember forever
That’s the kind of project that sounds simple until the walls open up and reveal years of hidden damage. Volunteering your time for a community shelter and still pushing through the rotted framing, grease buildup, and tight deadline says a lot. The new kitchen setup probably makes a huge difference for both the staff and the inspections — and earning a big bowl of chili afterward sounds well deserved.
Thanks for the article next time I will help do some charity so I can have more experience
I’m really glad you finally managed to get the heavy cement backer boards up and laid down a clean, solid row. Keep up the good work buddy
That’s really nice
That sounds like a brutal job, but the shelter was lucky to have someone willing to push through it fixing hidden damage under pressure is never easy, especially in an old commercial kitchen
Continue with the good work you’re doing buddy, let’s keep it going pal. Really nice work you’re doing
Watch: Kitchens renovation shorts
