Pot Lights in a 1970s Toronto Home - What Happened When We Opened the Ceiling
Had pot lights installed in our 1974 Toronto bungalow kitchen and living room. What the electrician found when he opened the ceiling is worth sharing as a cautionary tale for other older-home owners.
What We Planned
12 pot lights in the kitchen and 8 in the living room. Both rooms are directly below the attic. Went with ICAT-rated LED fixtures (IC + Air-Tight combined, integrated LED, 4-inch, 2700K).
What We Found
When the electrician opened the ceiling to run wires:
Kitchen: existing knob-and-tube wiring in parts of the ceiling. Required remediation before new fixtures could be connected. This added $1,800 to the project but it was not optional.
Attic above living room: insulation was blown-in vermiculite (1970s product, possibly contains asbestos). We had a sample tested. Result: non-detect for asbestos. Bullet dodged, but the test was $120 and necessary.
Final Cost Breakdown
20 ICAT LED fixtures: $1,600 (Halo brand from supply house)
Electrical labour (2 days): $2,400
Knob-and-tube remediation in kitchen area: $1,800
Dimmer switches (4 zones): $320
Permits + ESA inspection: $280
Total: $6,400
What I Wish Someone Had Told Me
Any electrical work in a pre-1980 Toronto home should budget 20-30% contingency for knob-and-tube discovery. Our electrician said it is present in the majority of 1960s-1980s Toronto homes they open up.
Also: specify ICAT explicitly to your contractor. “LED pot lights” is not specific enough. ICAT is the spec that matters for attic-adjacent ceilings.
