Ontario Bathroom Exhaust Fan Code and Upgrade Guide 2026
Bathroom Exhaust Fan Requirements for Ontario Homes
Bathroom exhaust fans are a critical but often underspecified component in Ontario renovations. Inadequate ventilation leads to mould, peeling paint, and structural damage. Here’s what GTA homeowners need to know in 2026.
Ontario Building Code Requirements
OBC Section 9.32 mandates mechanical exhaust for bathrooms without openable windows:
  • Minimum airflow: 25 L/s (53 CFM) for bathrooms with toilet and shower/tub
  • Must exhaust to exterior (never into attic or ceiling cavity)
  • Minimum 4-inch (101mm) duct diameter
Sizing Your Fan
  • Rule of thumb: 1 CFM per sq ft of bathroom area
  • Separate shower enclosure: add 50 CFM
  • Steam shower: 150+ CFM required
  • Target sone rating: 1.0 or less for quiet operation
Fan Types in 2026
Type Cost Notes
Basic exhaust-only $30-100 Standard replacement
Fan/light combo $60-200 Most common retrofit
Humidity-sensing fan $150-400 Auto-activates on humidity rise
Inline fan (attic/ceiling) $200-600 Quietest at fixture level
Critical Duct Installation Mistakes
  • Never exhaust into attic — causes mould and deck rot
  • Never use flex duct longer than 6 ft without support — sags and traps condensate
  • Never reduce duct diameter mid-run
  • Always insulate ducts passing through unconditioned spaces
Permit Requirements
Replacing fan on existing circuit: typically no permit needed. New circuit or fan: ESA permit required. Duct penetration through fire separation in multiplex: building permit for firestop.
Cost Guide
Scope Cost
Fan replacement (existing wiring/duct) $200-500
New fan + new circuit + exterior duct $600-1,400
Inline fan system, humidity-sensing $1,200-2,500
Ask bathroom ventilation questions on home.renovation.reviews.
LF Builders handles full bathroom renovations including exhaust fan upgrades across the GTA. lfbuilders.ca
