My Failed Quest for a Quick Carpet Fix
Our upstairs hallway had a single, agonizing squeak right outside the bedroom door. Every time someone stepped on it at 3:00 AM, it sounded like a cracking branch. Since we weren’t ready to replace the carpet yet, I bought one of those “as seen on TV” kits that lets you drive breakaway screws straight through the carpet and padding to anchor the loose subfloor to the joists.
​The instructions promised you’d never feel the screw heads. What they didn’t mention was the blind guesswork involved.
​Armed with a stud finder that kept giving false readings through the thick pile, I spent an hour drilling exploratory screws into the floor. Instead of hitting solid wood joists, I kept hitting empty air. The screw heads didn’t snap off cleanly like the box claimed; instead, the threads caught the loose carpet fibers, threatening to unravel a whole section of the hallway like an old sweater.
​The real breaking point came when I finally located the joist, drove the screw home, snapped the top off, and stepped on it only for a completely new, sharper squeak to erupt three inches to the left.
​The kit is back in the garage now. The original squeak is still there, joined by two of its friends, and my hallway looks like a minefield of slightly disturbed carpet dimples. Some quick fixes are just invitations to a much bigger weekend project.
Information learned online doest always give the most accurate methods.
Regarding your post about My Failed Quest for a Quick Carpet Fix — Solid question. A few things to consider: 1) local building codes (they vary by municipality), 2) your skill level / whether you’ll DIY or hire out, and 3) what your long-term plan for the space is. What’s your take on these?
