Minnesota Home Improvement Tips
Owning a home in Minnesota means playing a never-ending game of “Beat the Frost”. If you want to keep your home in top shape, you have to think ahead.
Prioritize the Envelope
Before the first flurry hits, check your attic insulation. Most older homes in the Twin Cities are under-insulated, leading to those dreaded ice dams. Ensuring you have a high R-value and proper ventilation can save you thousands in roof repairs and heating bills.
Seal the Gaps
Minnesota winds find every crack. Spend a Saturday with a caulk gun and weatherstripping. Focus on window frames and door sweeps. It’s a $50 fix that makes a noticeable difference in comfort when it’s -10°F outside.
Don’t Forget the Exterior
Gutter Cleaning: Do this twice—once in mid-fall and again after the last oak leaves drop.
Outdoor Faucets: Disconnect hoses early! A frozen pipe in the wall is a nightmare no one wants in January.
Keeping a home here is all about moisture management and heat retention. Stay proactive, and your home will handle the “Polar Vortex” just fine.
Well written, very insightful
I really enjoyed this article, keep it up
Nice pieces of information,
I found the writing measured and easy to absorb
well put together bro
