LVP V laminate Flooring, which one feels better daily
LVP and laminate flooring may look similar at first, but the way they feel during daily use is quite different.
LVP is usually soft under the feet because it is made with flexible vinyl layers. When you walk on it with your barefoot, it feels smooth, warm, and slightly cushioned, which makes it more comfortable for long hours of standing or walking around the house.
LVP also absorbs sound better, so footsteps are quieter, which helps in busy homes where people are always moving around.
Laminate flooring, on the other hand, feels hard and solid. This is because it is built on a rigid board, so the surface is not soft when you step on it. Some people like the firm feeling because it feels strong and stable, but it becomes a bit noisy and less comfortable over time.
In daily living, especially in areas like kitchens or living rooms where you spend a lot of time on your feet, LVP is easier and more comfortable to live with, while laminate is more rigid and solid.
So here, the choice is yours, which do you prefer, soft and quiet or hard and noisy?
LVP just feels softer and quieter to walk on daily, while laminate feels a bit more solid underfoot but can sound louder over time.
Laminate feels strong and solid, but that harder surface can become noticeable after standing for long periods
