Kitchen renovations in Ontario: trade sequencing, what triggers a permit, and where delays actually come from (2026)
Most of the questions we get on kitchen renovations aren’t about tile selection or cabinet styles. They’re about timing. “Why is my project already three weeks behind?” Or: “My contractor said I didn’t need a permit, and then the city showed up.”
Trade sequencing and permit management are where kitchen renovations run on schedule or don’t.
What actually triggers a permit in Ontario
Cosmetic work doesn’t require one. Replacing cabinets, countertops, or flooring, or just repainting, doesn’t involve city inspection as long as you’re not touching anything structural or the systems behind the walls.
Common kitchen scope often does trigger permits, though. Electrical is what most homeowners miss. Installing new outlets, adding dedicated circuits for ranges, ovens, dishwashers, or microwaves, or upgrading from knob-and-wire or older aluminum wiring all require an ESA permit and inspection. Replacing appliances on existing circuits is usually fine, but if those circuits are undersized or outdated, a licensed electrician won’t sign off without addressing that first.
Plumbing is the second common trigger. Moving the sink even a few inches means cutting into the drain, waste, and vent system. Drain lines need minimum fall (1/4 inch per foot), and adding a dishwasher or a second prep sink brings P-trap and air gap requirements. That needs a plumbing permit.
Any load-bearing wall work requires a structural engineer’s report and a building permit. That applies even to a partial opening for a pass-through. No contractor should frame it otherwise.
Gas has its own permit stream. Adding a gas range where the existing setup is electric, or running a gas line for a range hood with makeup air, both need a gas permit.
Who pulls the permit
In Ontario, either the homeowner or a licensed contractor can hold the permit. The permit holder carries the liability if work fails inspection, and if unpermitted work turns up during a sale.
A contractor who asks you to pull the permit for structural or mechanical work is moving that liability onto you. Sometimes there are legitimate reasons. Ask what they are before signing. Licensed general contractors routinely pull their own permits.
Trade sequencing: why the order matters
A kitchen renovation moves through a fixed sequence: demo, then an asbestos check on pre-1990 homes (drywall compound and old vinyl tiles are the usual suspects), then rough plumbing, rough electrical, and rough gas in parallel. After rough-in comes a framing inspection before any walls close. Then insulation if exterior walls are open, a drywall inspection, drywall, tile and flooring, cabinets, countertop template measurement, fabrication, countertop installation, plumbing fixtures, electrical trim, appliances, and a final inspection.
That gap between cabinet installation and countertop delivery is where most timelines fall apart. Stone isn’t templated until cabinets are fully installed and level. From template, fabrication runs two to three weeks. Good fabricators book up. Confirm their lead time before demo starts and build the schedule backward from their template-to-delivery window, not forward from the demolition date.
Without that lead time built in, you end up with exposed cabinets sitting for weeks while the rest of the project waits.
What a good quote should show
If a quote doesn’t include a schedule of works, or at least a rough phase sequence, ask for one before signing. It should answer: who pulls the permits, who are the subcontractors and are they named, are rough-in and finish work shown separately, and what is the full timeline including the countertop fabrication window?
A quote that lists labor and materials by room but doesn’t address sequencing or permit responsibility is missing information. Delays in kitchen renovations rarely come from the renovation itself. They come from permit processing times, inspection backlogs (currently 10 to 14 business days for residential rough-in in Toronto), and trade handoffs that weren’t mapped out before work started.
The allowances vs. inclusions question and line-by-line breakdown of a GTA kitchen renovation quote are covered in a related thread: Kitchen renovation quotes in Ontario: what each line item actually means (2026)
Questions on a quote you’re looking at, or a permit situation you’re working through? Post it here.
Track $RENO earnings on this topic. Top contributors earn tier-up rewards and climb the leaderboard. Claim your Solana wallet on signup: Welcome to $RENO — Quests, Rewards, Leaderboard
