Kitchen renovation quotes in Ontario: what each line item actually means (2026)
The standard advice is to get three quotes. The problem is that those three quotes usually arrive in completely different formats — one with line items, one lump sum, one dense PDF with no breakdown at all — which makes comparing them nearly impossible. This is what each section of a kitchen renovation quote actually covers in Ontario, and where the real variation tends to hide.
What a quote should break into (and what’s missing if it doesn’t)
A detailed kitchen renovation quote should have four main components: labour, materials, permits and disposal, and contractor overhead or project management. Some contractors bundle everything into a single number. That’s not a red flag on its own, but it makes comparing quotes very difficult and makes understanding cost overruns almost impossible.
Rough split for a mid-range GTA kitchen renovation in 2026:
  • Labour: 20–25% of total
  • Cabinets alone: 35–45% of total
  • Countertops, flooring, and fixtures: 20–30% depending on selections
  • Permits, disposal, and overhead: 10–15%
If your quote is missing a demolition and disposal line, ask about it directly. Haul-away for a mid-size kitchen demo typically runs $800–$1,500 in the GTA. If it’s not in the quote, it usually shows up as an extra.
Labour costs and where quotes diverge
Labour is where GTA quotes vary most between contractors. Toronto-area carpenters and tilers generally run $85–$125/hour; licensed plumbers $100–$150/hour; electricians $90–$130/hour. A quote well below these ranges usually means non-licensed trades, hour estimates that expand once walls open, or subcontracting to crews you haven’t vetted.
Ask whether the tradespeople on your project are employees or subcontractors, and who’s coordinating their schedule. Most kitchen renovation problems don’t happen within any single trade’s scope — they happen at the handoff between the electrician and the drywaller, or between the plumber and the tile installer.
Materials markup: what’s standard, what warrants a question
Contractors typically mark up materials 15–25%. That covers supplier relationships, delivery coordination, and defect liability if something arrives damaged. Markups above 35% on ordinary items — drywall, cement board, standard hardware — are worth asking about.
Where it gets complicated is client-supplied materials. Some contractors won’t install appliances or fixtures the homeowner sourced directly; if their plumber connects your range and it leaks, the warranty question gets messy. Others are fine with it. Know which model your contractor uses before you spend a weekend tracking down the perfect range hood.
Cabinetry is typically the single largest line item, and can run $15,000–$40,000 on a custom build. Ask whether the quote includes elevation drawings or just a cabinet count. Drawings lock down the design; a count leaves a lot open for interpretation later.
Permit fees: who pulls them matters
Any kitchen work in Ontario touching structural elements, plumbing rough-in changes, or the electrical panel requires permits. Fees typically run $200–$1,000 depending on municipality and scope. Contractors can pass these through at cost or add a small administration markup — neither is unusual.
The permit holder designation matters more than the fee amount. When a homeowner pulls their own permit, they take on legal responsibility for the work. That permit shows up in a title search when the house sells, and a kitchen renovation permit left open or closed by the homeowner rather than the contractor can stall a sale years later. The contractor should be the permit holder.
If a contractor doesn’t bring up permits at all during the quote process, that’s worth treating as a serious concern.
Allowances vs. included: they’re not the same thing
A quote with multiple large allowances is essentially an estimate with a firm-sounding cover number. An allowance is a placeholder. A “$3,000 appliance allowance” means the contractor has budgeted that amount; if you pick something at $4,500, the difference is yours.
Allowances aren’t automatically wrong — they’re useful when material selections aren’t finalized yet. But a quote with six or seven of them is really a rough estimate in disguise. Track every allowance against your actual selections before anything gets ordered.
A detailed quote will separate allowances from truly included line items so you can see exactly where you have exposure.
Deposit structure and payment terms
Standard practice in Ontario is three payments: a deposit at signing (roughly 20–30%), a second draw when materials arrive, and a final payment at substantial completion. Requests for more than 30% upfront before anything has been ordered are worth asking about. You should know what the deposit is funding.
Requests for more than 50% before work starts are a harder line.
Before you sign
A quote with no start date and no projected completion window is a problem. Kitchen renovations are disruptive in a way that’s hard to overstate — you need a real schedule, not “we’ll begin in a few weeks.”
A contract describing scope in vague terms (“kitchen renovation as discussed”) rather than specific ones (“replace 14 linear feet of base cabinets, reroute drain 24 inches north, install 52 sq ft quartz countertop”) gives you very little recourse if the finished work doesn’t match what you agreed to.
And a quote that comes in 20–25% below every other one you received isn’t a deal. It’s either a calculation error or someone cutting costs somewhere you haven’t been told about. Get the specific inclusions in writing and compare line by line before you decide.
If you’ve received kitchen renovation quotes and something looks off, post the details below. There are contractors on this forum who can tell you whether what you’re seeing is standard Ontario practice or something worth pushing back on.
Helpful contributions to threads like this earn $RENO, the forum’s community token. Wallet setup and onboarding are at Welcome to Home Renovation Reviews — Start Here.
