Is It Actually Worth Fixing Small Issues Immediately?
I’ve been thinking about this because I have a habit of postponing small fixes around the house.
Loose handle? I’ll tighten it later. Slight crack? I’ll check it another time. Something minor always feels like it can wait, but I’ve also noticed that some of those “small” issues slowly become bigger ones.
A loose hinge becomes a damaged door. A small leak becomes something more annoying. And then you end up spending more time fixing it.
At the same time, constantly fixing every little thing immediately can feel exhausting too. So I’m stuck somewhere in between.
Recently, I tried changing my approach fixing at least one small issue whenever I notice it instead of piling everything up. It’s not perfect, but it’s helping a bit. Still, I wonder how other people handle this.
Do you fix things immediately once you notice them, or do you wait until it actually becomes a problem?
Because honestly, I feel like most of us fall into that I’ll do it later trap.
That’s procrastination, and you should work towards changing
They don’t stay small so they slowly turn into bigger, more expensive problems, even if it doesn’t look urgent at first.
Most people delay small fixes until they grow. Prioritize early warnings, but avoid burnout by grouping truly minor issues later.
Yes I also feel like most of us fall into that I’ll do it later trap.
Thanks for sharing your thoughts buddy
Is it important to fix more issue when you see it’s don’t procrastinating because it will need to big problem and cost you more
