Last year, after a few heavy rains, I noticed water pooling around the foundation of my house. At first, I panicked, thinking Iβd need an expensive waterproofing job. But after a quick inspection, I realized the real problem was simpler: clogged gutters.
Leaves, twigs, and debris had built up over time, causing water to overflow and run down the sides of the house instead of draining away. I spent a Saturday morning clearing them out with a ladder, gloves, and a small scoop all tools I already had. It took about two hours and zero dollars, yet the impact was immediate.
After the cleanup, I tested the system by running water through the downspouts. The water flowed freely, and no pooling occurred around the foundation. What could have turned into foundation damage and costly repairs became a simple, preventive fix.
Sometimes, home maintenance is about paying attention to the small things. A little effort and awareness in this case, just cleaning the gutters can prevent headaches and save money in the long run.
