Fence installation in Ontario: cedar, vinyl, or aluminum — permit rules, costs, and what gets people in trouble
Fencing looks simple. You pick a material, find a contractor, and get a fence. In Ontario, that’s usually how it goes — except when the project lands near a property line, a pool, or a bylaw the homeowner didn’t know existed. Here’s what actually trips people up.
Permit triggers
Most GTA municipalities don’t require a permit for a standard residential fence under 2.0 metres in the rear or side yard. But a few situations change that:
Pool enclosures always need a permit, regardless of height. Ontario Building Code Section 8.3 requires a minimum 1.2m enclosure with self-latching gates and no footholds on the outside face — this applies to any new pool.
Front yard fences over 1.2 metres require a permit in Toronto, Mississauga, Brampton, and most Peel and York Region municipalities. Corner lots have tighter rules; the fence line can’t extend past the sight-line triangle near the street.
Retaining-wall and fence combos may trigger separate structural review if the combined height exceeds municipal thresholds.
Bylaws aren’t uniform across the GTA, so always check your specific municipality before starting.
The Line Fences Act doesn’t apply where most people think
Many Ontario homeowners assume the Line Fences Act (R.S.O. 1990) gives them a way to force cost-sharing with a neighbour on a shared boundary fence. It might — depending on where you live.
City of Toronto opted out of the Act entirely. The City doesn’t accept applications for fence viewing and has no role in resolving cost disputes between neighbours. If your Toronto neighbour refuses to contribute, there’s no legal mechanism to compel them.
GTA municipalities outside Toronto — Mississauga, Brampton, Markham, Vaughan, Ajax, and others — are still covered. Either party can request fence viewers, who are municipal appointees that assess the dispute and split costs. The process takes 3-5 weeks and costs each party $50-150 in administrative fees depending on the municipality.
Either way: get a registered property survey or a signed written agreement with your neighbour before starting anything near a property line. Survey mistakes found after a fence is already built are expensive. A survey runs $400-$800. Post-construction errors cost considerably more.
Material comparison
Cedar ($45-$75/linear foot installed) is the GTA standard for privacy fencing. It handles freeze-thaw cycles well, takes stain readily, and lasts 20-25 years with sealing every few years. Boards shrink and check unevenly over time — expect 3-4 replacements per 100 linear feet over the fence’s life. Worth asking your supplier whether you’re getting western red cedar or hemlock; some suppliers use “cedar” loosely, and hemlock weathers differently.
Vinyl ($45-$85/linear foot) is the right choice if you want zero maintenance. Warranties typically run 25-30 years and freeze-thaw performance is excellent. The repair issue is real: matching panels after a few years can be difficult if colours have shifted between production runs. Vinyl also looks obviously synthetic in older neighbourhoods with mature landscaping. Prices have come down significantly since 2022.
Aluminum ($35-$65/linear foot) is mostly used for pool enclosures, ornamental perimeter fencing, and front yard decorative work. It won’t rust, won’t rot, and powder coat holds up for 20-30 years. Privacy isn’t what it’s for — aluminum picket panels have gaps by design.
Post depth and the frost line
GTA frost depth runs 1.2-1.5 metres. Posts set shallower than 1.2m will heave after a wet winter. A fence that’s plumb in October can be visibly wavy by April. This is one of the more common shortcuts on low-bid jobs, and it means a full reinstall within a few years.
Standard: 1.2-1.5m deep holes, minimum 300mm diameter, concrete poured below frost line. Ask any contractor to specify post-hole depth in writing before you sign.
Timing
Spring (April-June) is peak fencing season in Ontario. Reputable contractors book out 4-6 weeks, and pricing runs 10-15% higher than off-peak. Fall (August-October) is the better window if you’re not in a rush: shorter wait times, dry ground, and concrete that cures before hard freeze.
What a complete quote looks like
A proper fence quote should spell out: linear footage, post material (pressure-treated lumber vs. metal sleeve), post-hole depth and diameter, concrete spec, gate count with hardware details (latch type matters for pool enclosures), removal of any existing fence, and permit acquisition if your project triggers one. If post depth isn’t in the quote, ask before signing anything.
If you’ve navigated a fence project in Ontario — bylaw surprises, contractor red flags, material performance after a few winters — drop your experience below. Useful contributions earn $RENO, our community token, and the best answers get surfaced to neighbours asking the same questions: What is $RENO and how do you earn it?
This is way more complicated than most people think good breakdown honestly
A lot of homeowners don’t realize Toronto opting out of the Line Fences Act changes everything. That alone can save people from serious neighbour drama.
Regarding your post about Fence installation in Ontario: cedar, vinyl, or aluminum — permit rules, costs, and what gets people in trouble — If budget is a concern, consider doing the posts yourself and hiring out only the panel installation. Posts are the hardest part to get right (plumb, concrete mix, drainage), and if they fail, the whole fence goes. What’s your soil type? Sandy drains well, clay needs deeper footings.
