Exterior Vs Interior Waterproofing Which Actually Makes More Sense?
I’m trying to understand the logic behind different waterproofing methods before I start talking to contractors. From what I’ve read, there are two completely different schools of thought when it comes to keeping a basement dry.
The first is exterior waterproofing, which means digging up the dirt all around the outside of your house, sealing the foundation walls from the outside, and installing a perimeter drain. This makes the most sense to me because it stops the water before it enters your home. But the excavation cost is astronomical.
The second is interior waterproofing, where they let the water seep through your walls, catch it in an interior trench, and pump it out with a sump pump. This is way cheaper, but aren’t you still technically letting your foundation walls stay wet and degrade over time?
I’d love to get some opinions from people who have done either method. Did you go the cheap route with an interior system, or bite the bullet for the full exterior excavation?
Digging up the yard was a total nightmare and hurt the wallet, but I just couldn’t sleep knowing my foundation walls were constantly soaked.
A full exterior excavation is the way to go
He external waterproofing ic he best but the cost is astronomical so that’s why people prefer interior waterproofing
Exterior waterproofing is superior because it prevents foundation degradation, but excavation is brutal. Interior systems protect your living space cheaply, but leave walls wet. Go exterior if you have the budget.
Exterior waterproofing prevents water entry but costs more; interior systems are cheaper but manage water after it enters foundation walls.
For me I do prefer interior waterproofing more than exterior waterproofing
Watch: Basements renovation shorts
