Eavestrough replacement costs in the GTA: spring 2026 guide
Spring is the window where most GTA homeowners discover their eavestroughs did not survive winter. The staining on the fascia, the seam that started dripping in February, the corner joint that heaved and buckled from the ice — these get noticed when the snow is finally off and you are walking the perimeter.
We just updated our 2026 eavestrough and gutter guard cost guide on the LF Builders blog with current pricing and some cold-climate detail that does not always get covered, so I wanted to open a conversation about what we are actually seeing on jobs right now.
Full guide: https://blog.lfbuilders.ca/blog/eavestrough-gutter-guard-cost-guide-2026/
What we are seeing on 2026 quotes
Basic aluminum eavestrough replacement on a typical GTA two-storey is starting around $4,000 before any guard or soffit and fascia work. If you add a micro-mesh guard system and a soffit and fascia refresh, that full package on an average house tends to land near $12,000. Those numbers have crept up modestly from 2025, partly because aluminum is in the same tariff pressure zone as the broader material market right now.
The thing worth knowing before you call anyone: the quote should always come with a line-item breakdown showing linear feet, number of downspout outlets, 5-inch versus 6-inch sizing, hanger spacing, and guard brand if applicable. A quote that just says “$3,800 — replace gutters” does not tell you anything, and you cannot compare it to anything.
5-inch vs. 6-inch: the choice
Toronto gets meaningful rain volume events — summer storms that dump 50mm in an hour are not unusual. On most two-storey GTA homes, 6-inch gutters are worth the modest upcharge ($300 - $600 for a full house) because they handle high-volume events without overflowing at the seams. The exception is a small bungalow with limited roof pitch — 5-inch is adequate there.
Gutter guards: worth it or not?
In a GTA neighbourhood with mature tree canopy, a quality micro-mesh guard system is worth the investment. Cleaning eavestrough gutters with guards becomes an occasional spot-check rather than an annual labour-intensive project. The caveat: cheap foam inserts or basic mesh covers actually trap fine debris inside the gutter and create worse clogs. The brands worth specifying are those with a fine stainless mesh that sheds debris off the surface in rain.
In a neighbourhood with minimal tree cover, guards are nice-to-have rather than essential.
What the spring booking window looks like
Eavestrough crews are calendaring May and early June already. If you need work done before the first real summer rain event, you want to be booking now. Lead times for seamless aluminum are shorter than for a framing or kitchen crew — but the better shops fill up fast once the ground is solid.
Worth checking: a few GTA eavestrough contractors are listed and reviewed in the home.renovation.reviews directory. Makes it easier to compare who is actually operating in your area.
Samm Simon is running 251 km for cancer research this spring — sammsimon.ca
Happy to answer questions about sizing, cold-climate detailing (ice dams are their own conversation), or what to look for in a quote. Drop them below.
Good timing on this guide. One thing I’d add for anyone getting quotes right now: ask specifically whether the contractor is doing seamless or sectional.
Seamless eavestroughs are roll-formed on-site from a continuous coil — no seams along the runs, only at corners and downspout outlets. That’s where most leaks start, so eliminating seams makes a real difference in a GTA climate where you’re cycling between freeze and thaw 20 or 30 times a winter. Most reputable GTA eavestrough companies run seamless as standard now, but budget shops still use pre-cut sectional — and the quotes look similar on paper.
On gutter guards: the micro-mesh systems mentioned in the guide are genuinely the right call if you have deciduous trees overhanging the roofline. The payback math is straightforward — two professional cleanings a year at $200-400 each adds up faster than people expect. That said, no guard system eliminates maintenance entirely. Even micro-mesh needs an annual rinse-down to clear fine debris that compacts on the surface.
Timing note: if you’re in the GTA and haven’t booked yet, mid-May is typically when the first scheduling crunch hits. Right now you can still get a quote and get on a May calendar.
