Creating Flow Between Rooms
Many homes suffer from the same problem: rooms that feel like separate worlds. Renovation can fix that by focusing on flow.
Consistent flooring is a great start. When the same material runs from room to room, the eye reads the home as larger. Repeated paint tones or trim styles quietly tie spaces together.
Openings matter, too. Widening a doorway by just a few inches can change how people move. I once saw a cramped kitchen suddenly “breathe” after the entry arch was opened up slightly nothing else changed.
Use furniture to guide movement, not block it. Avoid placing large pieces in natural walk paths.
Conclusion: Good design makes a house easy to navigate. When rooms connect visually and physically, daily life simply feels smoother.
This is good work buddy
wow so so impressive man
You are so right lad
You are making sense here.
This definitely cool fr keep up
Good to know, thanks for sharing.
