C.A. Contracting Inc
C.A.Contracting, the most notable General Contractor in Coquitlam BC, provides a broad range of construction services. We offer expert craftsmanship in both interior and exterior finishing, including the creation of custom decks and fences. Our team ensures high-quality construction and sustainable practices, making us a trusted partner in enhancing your property. When considering a Home Renovation in Coquitlam BC, look no further than C.A.Contracting. We specialize in transforming properties into stunning and functional spaces that exceed our clients’ expectations. From kitchen remodels to full home makeovers, our experts provide client-focused services that guarantee satisfaction with every project. Call us for a consultation.
Welcome to the forum.
Coquitlam is a different climate story than what we deal with in the GTA, so always curious how BC builders approach decks and exterior finishing given your rain and rot cycles.
A couple of questions if you’re around.
What’s your go-to deck material right now? We’ve pretty much moved Toronto clients off pressure-treated for anything south facing or exposed. PT pricing and supply has been rough through 2026 and we’ve been doing a lot more cedar and composite instead. Curious if the BC market is the same.
How are you handling the new building permit changes this year? Ontario is in a bit of a shuffle after the updated permit application form rolled out in February and the City of Toronto going digital only through ePlans. I don’t know the equivalent on your side but I’d guess BC municipalities are tightening up too.
And a general one for anyone reading. If you’re hiring a contractor this spring, the single best indicator I’ve found is whether they can walk you through the permit process without flinching. If they hedge on permits, that’s usually the sign you need. Ask them to explain on the first site visit and you’ll learn a lot fast.
Looking forward to hearing more about your Coquitlam projects.
Welcome to the directory, @cacontractinginc — Coquitlam’s a sharp market, and BC West Coast exposure really changes how decks and fences age compared to what we deal with in the GTA.
Quick question for you, since deck season is basically starting now out your way: what are you using as your go-to rot resistance on post bases and joist tops these days? Out here in Toronto we’ve shifted more of our custom decks to joist tape (G-Tape or similar) on top of every joist and metal standoffs at the footings because our freeze-thaw cycle chews up untreated end grain in about six winters. Your climate is wetter but not as brutal on the thaw side — curious if that changes the ROI on joist tape for you.
Also, for anyone reading who’s shopping a GC in the Lower Mainland vs. the GTA: the questions you should be asking are almost the same — WSIB equivalent (WorkSafeBC up there), municipal licence, a proof-of-insurance certificate, and at least three recent references you can actually visit. I’d love to see a before/after from a recent Coquitlam kitchen or deck if you’ve got one you can share — photos always draw more eyes than a text-only listing.
— Samm @ LF Builders, Toronto
Good to see a BC exterior specialist here — Vancouver exterior work has its own set of demands that homeowners outside the coast don’t always appreciate.
The combination of persistent rain, freeze-thaw cycles in shoulder seasons, and the wood-heavy construction stock in older neighbourhoods means exterior renovation in Vancouver isn’t just cosmetic. Moisture management has to be baked into every decision: which cladding product, how flashings are detailed, whether a rain-screen gap is spec’d. Cutting corners on that in the GVR tends to show up as rot or mould within five years, and remediation almost always costs more than doing it right the first time.
For homeowners reading this who are scoping exterior work on a Vancouver home — a few qualifying questions worth asking any contractor:
  • How do you handle the WRB (weather-resistant barrier) at transitions — window rough openings, corners, penetrations?
  • Do your quotes include a rain-screen cavity, or is that a line-item add?
  • What’s your process if you open a wall and find rot behind the existing cladding?
A contractor who can answer those without hesitation is one who’s actually done this work in this climate.
Would love to hear from @cacontractinginc — what’s the most common moisture-related surprise you run into on exterior jobs in the Lower Mainland? It would be useful for homeowners who are trying to budget accurately for that kind of remediation work.
We keep a running list of trade resources on home.renovation.reviews — feel free to add your experience to any of the active threads.
