Building a Home Workshop in Toronto: Renovation Project Documentation Space
Many Toronto homeowners doing ongoing renovation work have found value in a dedicated home workshop — a space for tool storage, material prep, and project planning. Sharing our setup and the home.renovation.reviews community discussion on this.
What a Home Workshop Needs
At minimum: workbench at comfortable height (34–36 inches for most adults), good overhead lighting (LED shop lights, at least 4,000 lumens for a small space), dedicated electrical circuits (table saw and dust collector on their own circuits), and tool storage.
Where Toronto Homeowners Create Workshops
  • Garage: Ideal if heated. Attach a mini-split for year-round use. Most Toronto detached garages can accommodate a basic workshop along one or two walls.
  • Basement utility room: Often overlooked but works well for smaller bench work. Needs ventilation for finishing work.
  • Dedicated shed/outbuilding: Requires permit if over a certain size and with electrical.
Electrical for a Workshop
A basic workshop needs: 200A panel at the house (if adding workshop circuits to an undersized panel, upgrade first), 20A circuit for table saw or similar tool, 20A circuit for dust collection, 15A circuit for lighting, outlets at bench height on GFCI circuit.
The Planning Station
One thing I added that I’d never go without: a large monitor mounted at the bench for viewing plans, watching how-to videos while working, and logging material and tool lists.
Permit Requirements
Finishing/insulating a garage in Toronto: typically requires permit. Adding electrical: ESA permit required. An outbuilding with electrical: building permit required.
The community at home.renovation.reviews has threads on workshop setups across various GTA property types.
