Adding an In-Law Suite in Toronto: What It Costs in 2026
Spring tends to be when I hear a version of the same conversation from clients: an elderly parent had a health scare, or a family is tired of the cost of assisted living, and someone in the household has started asking whether they can build a space for mom or dad at home.
It is a real shift happening across Toronto and the GTA. More families are choosing to renovate their existing home to accommodate multiple generations under one roof instead of paying for a long-term care facility, a second mortgage, or ongoing commutes between houses.
I have been doing this work for over 50 years. Here is an honest guide to what you are actually looking at.
The core question: main floor or basement?
The two most common approaches are a main-floor conversion and a basement build.
A main-floor conversion typically means reconfiguring an existing bedroom and an adjacent bathroom into a private suite with its own entrance if possible. This works well when the parent or family member has mobility limitations, because it avoids stairs entirely. Cost in the GTA in 2026: roughly $40,000 to $80,000 depending on whether you need a new bathroom, laundry hookup, and exterior door.
A basement suite is often cheaper to build but harder to make accessible. You are looking at $60,000 to $120,000 for a full legal second suite with separate entrance, full bathroom, kitchen or kitchenette, and proper egress windows. If the basement needs underpinning first, add another $30,000 to $60,000. Not every basement qualifies - ceiling height matters, and the permit path is more involved.
What permits are required?
Yes, you will need a permit almost every time. Any new kitchen, bathroom, or separate entrance triggers a building permit application in Toronto. Timeline in 2026 is roughly six to ten weeks from a clean submission to permit in hand. That means if you are hoping to have a suite ready for a family member by September, you need to be submitting drawings now.
Heritage properties in established neighbourhoods add another layer. If your home is in a Heritage Conservation District - parts of Cabbagetown, Rosedale, the Annex - expect four to eight extra weeks for heritage staff review.
What makes a good in-law suite vs. a legal second suite?
An in-law suite and a legal second suite are not the same thing. A legal second suite has to meet the Ontario Building Code for fire separation, egress, ventilation, electrical, and minimum room dimensions. It can also be rented out if family circumstances change, which gives you flexibility.
An in-law suite that is not fully legal may meet day-to-day family needs but cannot be rented and may create complications at resale. I would always push clients toward the legal route - the incremental cost is modest and the long-term flexibility is worth it.
One thing families consistently underestimate
It is not the construction - it is the design decisions around shared vs. private space. Who has access to the laundry? Is there a shared entrance? How does heating get split? These feel like small questions until they become daily friction points. Getting a clear brief before you start drawing plans saves a lot of revision fees.
If you are early in this process, the most commonly asked questions thread is a good place to start before reaching out to a contractor. And if you are also weighing whether the space could serve as a rental down the road, the legal second suite guide covers that side of the math in more detail.
Happy to answer specific questions below - I hear a lot of the same ones.
BuildersLTD | LF Builders, Toronto ON | 50+ years, 30,000+ GTA projects
Frequently Asked Questions
Q: What does adding an in-law suite to a Toronto home cost in 2026?
A basement in-law suite conversion (existing unfinished basement, creating a self-contained unit with bedroom, bathroom, kitchen, and separate entrance) typically runs $80,000 to $140,000 in the GTA in 2026 for a proper permitted build. The cost spread is driven by existing basement height (lowering a slab adds $15,000 to $35,000), whether a separate entrance already exists or needs to be cut, the kitchen and bathroom specification, and how much electrical and plumbing needs to be brought to current code. Main-floor additions or purpose-built garden suites run higher — $150,000 to $250,000 for a properly engineered detached or semi-attached accessory dwelling.
Q: What permits are required for an in-law suite or secondary unit in Toronto?
A building permit from the City of Toronto (or applicable GTA municipality) is required for any new secondary unit. The permit process includes zoning review (confirming the lot and dwelling meet the City’s secondary suite zoning provisions), building code compliance for the unit itself (minimum ceiling heights, egress window requirements, fire separation between units), and plumbing and electrical permits. Toronto’s as-of-right permissions for secondary suites in most residential zones make zoning approval relatively straightforward; the building code compliance side is where most projects require the most pre-planning.
Q: What is the difference between an in-law suite and a legal second unit in Ontario?
The terms are often used interchangeably but have a meaningful legal distinction. A legal second unit (or “accessory dwelling unit”) is a registered secondary suite that meets all Ontario Building Code requirements, has a municipal building permit, passed inspections, and is registered on the property. An in-law suite that is built without permits or that does not fully meet OBC fire separation, egress, and utility requirements is an unpermitted unit — it may be occupied by family but cannot be legally rented to a non-family member, may not be insurable, and creates disclosure obligations at resale. The cost difference between a permitted and unpermitted suite is primarily the permit fees and inspection process — not the construction itself.
Q: Can the rental income from a Toronto in-law suite offset the construction cost?
In most GTA neighbourhoods, a legal basement suite generating $1,800 to $2,400 per month covers $21,600 to $28,800 per year. On an $80,000 to $100,000 construction cost, the gross payback period is 3.5 to 5 years before operating costs. That math works for most Toronto homeowners planning to hold for more than 5 years. The stronger case is often made by combining the rental income math with the capital value added to the property — a legal second unit adds a measurable premium to resale value in the GTA market relative to an equivalent home without one.
For more renovation guides and how-tos, visit the LF Builders renovation blog.
Two days in and I am already hearing this question on three different jobs, so let me add what is coming up in conversations this week.
Permit timing is the big shifter for spring 2026. Toronto raised the base permit fee 4% on January 1, and the planning application bump (4.82%) hits anything that needs zoning relief - which most basement in-law conversions do once you start adding a second kitchen or a separate entrance. If you are aiming for a fall move-in for a parent or adult child, your application needs to be in the queue by mid-May, not June.
The other thing nobody quotes upfront: ESA inspection wait times. Adding a second suite usually means a panel upgrade and a separate sub-meter. We have been seeing 3-4 week ESA scheduling lately in the GTA, and that is after the electrical rough-in. Build that into your timeline, not after it.
Cost-wise, a finished separate-entry basement suite in a Toronto detached is sitting around $85K-$140K right now depending on whether you have headroom (under 6’8" you are looking at underpinning, which can add $40K+). Walkout lots are noticeably cheaper than below-grade. Lumber and steel are finally easing per recent trade-data - about 3-5% softer than peak - but skilled-labour rates have not followed.
If anyone here is mid-quote on a project like this, drop the rough scope below - happy to flag where the surprises usually hide before you sign. The federal Multigenerational Home Renovation Tax Credit (up to $7,500) is also still on the table for qualifying suites, and most homeowners I talk to do not realise it stacks with HST rebates.
