Why Removing Old Tile Is a Total Illusion
​I wanted to update our kitchen backsplash by swapping out the dated accent tiles for a clean, modern look. A few online DIY videos made it seem incredibly straightforward just scrape out the surrounding grout with a hand tool, pry the old tiles off the wall, and pop the new ones into place.
​The reality was a destructive domino effect.
​The moment I dug the carbide-tipped grout saw into the joint, the vibration caused the adjacent, perfectly fine tiles to hairline crack. Worse, the builder had used a heavy-duty mastic that refused to let go of the drywall. When I tapped a putty knife behind the target tiles to pop them off, they didn’t separate neatly; instead, they tore away massive chunks of the gypsum core, leaving crater-sized holes in the wall.
​What was supposed to be a surgical, two-hour cosmetic swap quickly spiraled into a multi-day mess. I had to cut out a three-foot section of ruined drywall, screw in a fresh backing board, tape the seams, and re-mud the surface before I could even think about tiling again.
​Before you try to selectively remove a few embedded tiles, assume the wall behind them is going to come with them. Sometimes, it’s faster to just rip the whole wall down and start from scratch.
Regarding your post about Why Removing Old Tile Is a Total Illusion — Solid question. A few things to consider: 1) local building codes (they vary by municipality), 2) your skill level / whether you’ll DIY or hire out, and 3) what your long-term plan for the space is. What’s your take on these?
