Why I Ignored a Hissing Valve Until My Ceiling Fell
Every time the steam heat kicked on during the winter, the radiator in our guest bedroom made a faint, rhythmic ticking sound, followed by a soft hiss of escaping steam. It was an old house, and I figured the clanking gave it character. I kept a small towel underneath the valve to catch any minor condensation and added “bleed the radiator” to my never-ending spring to-do list.
​I didn’t realize the system was slowly venting water directly into the floorboards.
​While the towel caught the visible moisture on top, a steady, microscopic spray of boiling water was shooting out the backside of the cracked air vent, directly hitting the baseboard. Over three months of a brutal winter, that steam found its way through the gap between the floor and the wall, completely saturating the plaster ceiling of the dining room directly below.
​The wake-up call came at 2:00 AM on a Tuesday. A loud, wet thud echoed through the house. The weight of the soaked plaster had finally given out, bringing down a four-foot chunk of the dining room ceiling right onto our dining table, along with a cascade of wet insulation and decades of black dust.
​Fixing the radiator took exactly five minutes and a $12 replacement valve. Fixing the dining room required a professional drywall crew, a week of living under plastic sheeting, and a massive cleanup. Old house noises aren’t “character” they’re warnings. Turn off the system and fix the valve before the house fixes it for you.
That’s the scary part about old house problems, small noises seem harmless until hidden damage shows up later. A tiny leak over months can quietly ruin way more than people expect.
I’m so sorry but why do you ignore that kind of thing from the beginning next time you have to fix a little thing before it turns out to be a big problem
This is one of the problems of old houses. And this is also due to negligence, once you discover any fault try to resolve it on time.
It’s not advisable to ignore small faults at home before it turns out to something too serious
Watch: Ceilings renovation shorts
