Why Cheap Plastic Covers Cost Me a Basement
Every time it rained heavily, I noticed a tiny puddle forming near the baseboard in my finished basement. I figured the cheap, flimsy plastic bubble cover over the exterior window well was just slightly cracked, letting a little water drip down. I planned to grab a $20 replacement from the hardware store next time I ran errands.
​Then, a massive spring thunderstorm hit.
​The cheap plastic cover didn’t just leak; under the weight of the downpour, it cracked completely in half and collapsed into the well. Within minutes, the window well turned into a miniature aquarium. The drain at the bottom was completely choked with years of decaying leaves and mud that I had ignored because the cover had hidden them from view.
​With nowhere to go, the water pressure forced its way straight through the seals of the basement window frame. I woke up to two inches of standing water ruining my new drywall and soaking into the carpet padding.
​Fixing it required renting a heavy-duty submersible pump, digging out three feet of soaked gravel, clearing the drain line, and upgrading to a custom-fit, reinforced polycarbonate cover that can actually handle a heavy load. It was a brutal reminder that hiding a problem under a cheap piece of plastic doesn’t make it disappear it just lets it build up pressure.
It would have been better if you had gotten a quality plastic instead of a cheap plastic.
When getting any items for renovation it’s better you go for quality and maybe hire someone more experience in the job so it can be fixed properly
A simple window well cover issue escalated into major basement flooding, showing how neglected drainage problems can cause serious damage.
A small leak always seems harmless until a big storm exposes everything at once. Once water gets into a basement the damage spreads fast and cleanup gets serious quickly.
Watch: Basements renovation shorts
