Why April is quietly the best month to book a GTA reno
Short version: mid-April through early May is the cheapest, least-stressful window to lock in a GTA renovation this year. After mid-May the queue closes fast, and by June contractors are picking jobs, not competing for them. If you’ve been sitting on a quote since February, this is the week to call back.
Here’s why it matters, and what to watch for.
The shoulder-season discount is real
Reliable trade data this year has April-May and September-October pricing coming in 5-10% under peak summer bookings across the GTA. It’s not a sale. It’s a scheduling gap. Crews have trucks and days to fill between winter interior work and the summer outdoor push. Call in July asking for a patio in August and the crew is already stacked through September, which the quote reflects.
Materials are not the pressure point in 2026. Lumber and plywood are flat to softer versus last year. The line item that actually moved is labour: residential construction wage agreements that closed in mid-2025 are washing through quotes now, and some trades are up close to 20% year-over-year. That cost is fixed by the time your quote arrives, so the only real lever you have left is when the crew is idle versus stacked.
The permit queue is about to tighten
April through October is when the City of Toronto ePlans backlog gets ugly. Standard residential applications still land in the 10-20 business-day window this spring, but incomplete submissions tack on another 2-4 weeks, and the closer you get to summer the longer that tail gets. FASTRACK (for zoning-compliant projects under 100 m²) is still approving in 5-10 business days right now. That lane starts to thin out in May when everyone files at once.
If you already have a contractor you like, ask them to file this month. Filing in April and starting in late May costs you nothing. Filing in June and hoping to start in August can cost you the season. For the longer thread on what’s actually slowing permits down this year, see the permit delay discussion.
3 signals a contractor is already stacked
You’re calling in April, the good window, but not every outfit still has room. Signs a quote is going to disappoint you:
  1. Vague start date. “Sometime in June” means they’re juggling and your job is back-pocket filler. Ask for a written start date tied to permit-in-hand, not a month range.
  2. Scope shrinking mid-conversation. Solid contractors ask what you need and price it. A contractor who starts trimming things you asked for, or pushes you toward “the simpler version,” is trying to fit you into a slot someone else cancelled. That’s fine if you wanted the simpler version. Not fine if you didn’t.
  3. Deposit-first, deposit-big. Standard in Ontario is a moderate deposit at signing, milestone payments against work completed, and a holdback at the end. A 40-50% ask up front in April, on a job starting in July, is either a cash-flow problem on their side or a placeholder to keep their schedule flexible. Either way it’s your money sitting idle.
More on this in the contractor-committing thread.
What to line up this week if you want the window
Decide one thing first: are you renovating to live in it, or renovating to sell in the next 24 months? The answer changes what’s worth spending on.
Get 3 quotes, not 2 and not 5. Two leaves you without a reality check. Five is a part-time job.
For exterior work (patio, interlock, eavestrough, waterproofing, drainage), drainage comes first. The backyard-prep piece covers the sequencing.
If your project needs a permit and you haven’t filed, ask your contractor when they plan to submit. “This week” is the answer you want. “Once we’re closer to starting” means your project is on their back burner.
If you’re sitting on a quote, got one you’re not sure about, or just want a second set of eyes on the pricing line, drop it in this thread. This is exactly the kind of week where an hour of comparing notes saves a lot later.
One thing worth adding here for anyone reading: not all trade types are equally available right now, and knowing which ones are still open changes how you should sequence the project.
Interlock and hardscaping crews are the most time-sensitive right now. Ground is thawed, crews are coming off winter, and the good ones are filling their May-June slots this week. If your project has any outdoor component - patio, walkway, drainage grading - that crew should be your first call, not your last. Once they’re booked, you can fit the interior trades around them.
Kitchen and bathroom contractors have a bit more give right now, but it evaporates fast once school lets out in June and families start wanting the disruption done before summer. If your reno touches a main bathroom or kitchen, locking the start date in the next two weeks keeps you on the right side of that curve.
Waterproofing and foundation work is actually the one trade that doesn’t care about season the same way - they work year-round - but spring is when the problem reveals itself. If you’ve had any water in the basement this melt season, get eyes on it now before quotes climb with demand.
The sequencing question I’d add to the list above: if your project involves both exterior and interior work, which one is permit-dependent? That’s the one to move first, because permit timing drives everything downstream.
If anyone’s sitting on a specific quote or project and wants a gut-check on timing or sequencing, drop it here. Happy to take a look.
One thing worth adding for anyone comparing quotes right now: ask the contractor specifically which week they plan to submit the permit, not just “this spring.”
We’ve seen a pattern where homeowners get a signed contract in April but the contractor doesn’t file until mid-June because they’re still finishing a winter project. You’ve locked in a rate but you’ve accidentally bought a summer permit slot, not a spring one. The rate stays, but the scheduling pressure you were trying to avoid comes back anyway.
The practical fix is simple. When you sign, add a line to the contract: “Permit application to be submitted by [specific date].” Most reputable contractors won’t push back on that because they were going to file anyway. If someone resists it, that tells you something about how organized their schedule actually is.
Also worth flagging for anyone doing exterior work this spring — drainage and grading sequence matters more than people expect. A lot of interlock and patio quotes this time of year get delayed because the homeowner didn’t realize the drainage work has to come first, or the contractor didn’t flag it clearly. If you’re doing anything in the backyard, ask the contractor to walk you through the sequence before signing, not after.
Happy to look at any quotes people want a second set of eyes on. That’s exactly what this thread is here for.
One thing worth adding to the exterior work point: waterproofing and drainage jobs have a tight April logic that is separate from the scheduling-gap argument.
Spring thaw is the best diagnostic you can get. If you had a wet basement corner, a slow-draining backyard, or any efflorescence showing up on your foundation walls this past month, that is fresh evidence. A contractor walking your property in April can see where water came from, not just where it ended up. By July those clues are dry and you are back to guessing.
The sequencing matters too. If you are doing any combination of interlock, a patio, or foundation waterproofing, drainage needs to be scoped first - not because it costs the most but because the drainage grade dictates where everything else goes. Get that wrong and you are redoing the patio in three years.
On the permit point: FASTRACK is genuinely fast right now for qualifying jobs, but the submission has to be clean. An incomplete drawings package is the single most common reason a 5-day approval turns into a 3-week wait. Ask your contractor specifically who on their end prepares the drawings and whether they have had recent FASTRACK approvals. A yes-or-no answer tells you a lot.
