Why a Loose Wire Cost Me a New Circuit
One of the recessed lights in my home office started doing this faint, occasional flicker. It wasn’t constant just a quick blink every hour or so, easily ignored if I was focused on my computer screen. I kept telling myself it was just a cheap LED bulb reaching the end of its lifespan, and I’d swap it out whenever I got around to buying a pack of replacements.
​The real problem wasn’t the bulb; it was a loose wire nut inside the junction box.
​Because the connection was slightly loose, every minor vibration in the house caused the electrical current to arc. Over several months, that tiny gap generated a massive amount of hidden heat. I finally acted when the light stopped flickering and just went completely dead, accompanied by a faint, ominous smell of burnt plastic.
​When I pulled the fixture down out of the ceiling, I found the plastic junction box partially melted. The loose connection had charred the copper wire so badly that the insulation had crumbled away, leaving exposed, brittle wiring that was a major fire hazard.
​Instead of a simple two-minute bulb swap, I had to cut open a patch of the ceiling drywall, cut back the damaged wire to where it was still healthy, and fish a completely new section of Romex back to the switch. If a light is flickering, don’t just blame the bulb check the connection before that tiny arc cooks your wiring.
A flickering light can signal dangerous wiring issues; ignoring it risks overheating, damage, and serious electrical fire hazards over time.
