Volunteering to fix up a charity home kitchen
A local community shelter needed some urgent contractor work done on their main kitchen prep area before their seasonal inspection, so I offered to head down there for a weekend to handle the demo and tile work. The facility manager told me it just needed some fresh backing board and a clean layout of basic ceramic tiles behind the heavy industrial ovens. Honestly, dealing with commercial grade grease buildup and ancient wall studs turned the quick volunteer shift into a massive, exhausting grind.
The nightmare started the second the old plastic wall panels came down. Decades of heavy cooking steam and hidden leaks had completely rotted out the bottom framing timbers behind the stoves. You couldn’t even drive a drywall screw into the wood because the studs had turned into absolute mush. I had to pivot the entire plan immediately, clear away the damp insulation, and sister brand new studs directly to the old frame just to create a solid structural wall that could actually support the weight of the new tile sheets.
Then came the absolute worst part, scrubbing the surrounding brickwork to get the mortar to stick. Commercial kitchens accumulate a thick, stubborn layer of invisible grease that standard soap won’t even touch. I spent three straight hours hunched over in a hot, unventilated room with a heavy wire brush and an industrial degreaser, scraping the walls until my wrists were totally numb. Every splash of the chemical cleaner felt like liquid fire on the small cuts on my hands, and the fumes were so strong I had to keep stepping outside just to catch a breath of clean air.
We finally managed to get the heavy cement backer boards up and laid down a clean, solid row of white commercial tiles right before the weekend deadline hit. The shelter kitchen looks a thousand times brighter now, and the inspectors are going to be completely thrilled with the sanitary layout. The shelter staff actually made a massive batch of fresh chili for everyone who helped out, which was an amazing way to wind down after spending forty eight hours straight covered in plaster dust and grease.
Thank you for volunteering to fix up a charity home kitchen, that’s humanity and you deserve all the good things in the world
Volunteering for something like that honestly feels different in a good way it’s less about the space looking perfect and more about just making it usable and welcoming for people who need it.
I have not done this before but with your experience it looks good and I will fix a day to do one
Watch: Kitchens renovation shorts
