The Ceiling Shock What I Learned Trying to Skim-Coat My Stucco
After living with a heavy, dated texture on my living room ceiling for years, I finally decided to smooth it out. I wanted that pristine, gallery-flat look. A few online tutorials convinced me that instead of the messy nightmare of scraping the old plaster down, I could easily “skim-coat” right over it with a few thin layers of joint compound.
​It sounded simple, but working against gravity turned the project into a physical punishment.
​My first mistake was underestimating the sheer weight of wet drywall mud. Rolling it onto a ceiling requires an entirely different level of upper-body endurance than a wall. Within twenty minutes, my shoulders were screaming, and half the mud was dropping onto my protective plastic sheeting instead of sticking to the stucco.
​The real breakdown happened during the sanding phase. Because my coats weren’t perfectly even, I had to sand down the high spots while looking straight up. Even with a vacuum attachment, an incredibly fine, ghostly white dust filled the room, getting past my respirator and settling into every crevice of the house.
​The ceiling is beautifully flat now and makes the entire room feel twice as large, but the grueling physical toll was immense. If you are thinking about smoothing out a textured ceiling, don’t skimp on the prep work hire a professional lifter tool, or just save up to pay a pro who has the right scaffolding and shoulder muscles for the job.
That’s right this work is exhausting when working on other either get a professional or use the right heavy machinery to ease the work .
