Swapping a regular toilet for a smart one is a total plumbing disaster
I finally pulled the trigger on one of those high tech smart toilets with the heated seat and the automatic flush, thinking it would be a direct swap since the bathroom layout was already done. I completely underestimated how annoying it is to deal with hidden electrical requirements and ancient floor flanges. What should have been a quick unbolt and drop project turned into a full day of mopping up dirty water and fighting with a wax ring.
The first massive headache was wrestling the old porcelain bowl off the floor. Those closet bolts were so rusted into place that my wrench kept slipping, and when the unit finally cracked loose, a bunch of stagnant, rusty water leaked straight out of the trap and soaked the bathroom rug. Cleaning up that slimy mess while trying to scrape forty years of old, sticky wax off the floor flange with a putty knife was easily the most disgusting thing I’ve done all year.
Then came the real surprise that the manual completely glossed over. These smart toilets need an actual GFCI electrical outlet right next to the bowl to power the seat heater and the digital controls, and my bathroom only had one outlet way over by the sink mirror. I had to spend two hours hunched over under the baseboards trying to fish an extension line through the vanity cabinet without pinching the main water supply lines. Trying to lift that massive, heavy ceramic smart base onto the fresh wax ring perfectly straight while blind matching the floor bolts was an absolute nightmare.
The water supply valve leaked the second I turned the main house line back on because the new braided hose didn’t seal right against the old brass threads. I had to shut the whole system down again, wrap the pipes in a mountain of Teflon tape, and crank it down with vice grips until the dripping finally stopped. The heated seat works now and the digital buttons light up, but the automatic lid opener keeps glitching out and opening every time the bathroom door swings shut. I am leaving the manual on the counter and going to get some air because dealing with high tech plumbing has completely fried my brain.
The hardest part wasn’t even the toilet itself, it was discovering I needed a proper GFCI outlet nearby, which my bathroom didn’t have.
High tech bathroom, just stay with modern one.
Goodluck though
Smart toilets look simple online until old plumbing, hidden wiring, and leaking fittings turn a quick upgrade into an exhausting project.
Not all toilet can be swapped the way it’s being placed are different there are so many changes in the new ones
Change of the pipes and other bathroom stuffs isn’t an easy task
That’s a full-blown “modern upgrade meets old plumbing reality” situation :sweat_smile:
Smart toilets look like a simple swap on paper, but the electrical requirement + old flange + stubborn seals turns it into a full renovation job fast. At least it’s installed now—even if it’s still acting a bit haunted with the auto lid.
Morden renovation is very good, I will adop this system very soon
Watch: Bathrooms renovation shorts
