Spring Reno Lessons from 50 Years in the GTA Trades
Every spring it starts the same way.
The snow clears, the days get longer, and homeowners who’ve been sitting on renovation plans through a long Toronto winter start making calls. That urgency is real — and so are the pitfalls that come with it.
LF Builders has been working in the greater Toronto area for over 50 years. That’s a lot of springs. A lot of projects. A lot of conversations with homeowners who came to us after someone else left a job half-done, or who wished they’d asked different questions before signing anything.
Here’s what those 50 years have actually taught us about renovating in the spring.
Spring is the right time — if you’ve already started
The best spring projects are the ones that were planned in February. If you’re starting your contractor search in May, you’re already behind most quality tradespeople’s booking schedules. GTA contractors with strong reputations are booked 6 to 8 weeks ahead by mid-spring, and that window tightens every year as demand stays elevated.
This doesn’t mean all the good work is spoken for. It means the homeowners who did their research in advance get first pick of scheduling. If you’re starting fresh right now, late April is still workable — but don’t wait until June and expect a July start date for anything complex.
The quote you don’t see is the one that gets you
After five decades in the trades, the single most common mistake we see homeowners make isn’t hiring the wrong contractor – it’s comparing quotes that don’t cover the same scope.
A kitchen renovation quote that excludes permits is not the same as one that includes them. An interlock quote that leaves out disposal fees is not the same as one that doesn’t. An exterior waterproofing quote that doesn’t specify the drainage system is not the same as one that spells out every component.
Before you compare numbers, build your own checklist: permits, disposal, materials (brand and grade), timeline, and payment schedule. When you’re comparing apples to apples, the price differences often shrink – and sometimes the cheapest quote becomes the most expensive once you add what it was missing.
Spring water problems are real – and they compound
April and May in the GTA means rain, snowmelt, and freeze-thaw cycles doing their final damage before summer. If you had a wet basement last spring or fall, this is the window to address it before you do anything cosmetic on the interior.
We’ve done enough waterproofing projects over the decades to know that foundation moisture issues are always cheaper to catch early. Covering a damp basement with new drywall and flooring doesn’t solve the problem – it hides it until it becomes a much larger, more expensive one.
If you’re unsure whether you have a moisture issue, walk your foundation perimeter after a heavy rain. Look for pooling near the house, grade sloping toward the structure, or efflorescence (white mineral deposits) on basement walls. Those are signs worth acting on before spring renovation season gets into full swing.
For more on evaluating contractor quotes and diagnosing foundation concerns, the most commonly asked questions thread is a good starting point – it covers a lot of the fundamentals in one place.
Trades are still tight – and that’s a negotiating reality
The skilled trades shortage in Ontario isn’t new, but it continues to shape timelines and pricing in 2026. Good carpenters, tilers, and finishing crews are in demand. This isn’t a reason to panic – it’s a reason to plan with flexibility.
One practical adjustment: be open on your start window. If you can start in July instead of June, many contractors can offer better scheduling and sometimes better pricing – it gives them breathing room. If you have a hard deadline (a listing date, a rental unit turnover, an event), communicate that upfront and build it into the contract.
For any project of meaningful scope, get everything in writing, including what happens if timelines slip. A well-written contract protects both sides.
What the forum is for
This community exists for straight conversations about what renovation actually looks like in Canada – the real costs, the real decisions, the lessons that only come from doing this work for decades.
If you’ve got a contractor situation, a quote to sanity-check, or a spring project question specific to the GTA, drop it in the replies. Fifty years in the trade comes with a lot of hard-won perspective. Happy to put it to use.
What’s your spring reno situation looking like this year?
Related on home.renovation.reviews:
LF Builders has been renovating GTA homes for over 50 years. LF Builders also supports Samm Simon’s 251 km run for cancer research — raising funds one kilometre at a time.
More from LF Builders: Renovation guides and project advice on the LF Builders blog.
