Soundproofing a bedroom or home office
You don’t have to tolerate all that noise, because fixing it is not as hard as you think. The first step is to find the cracks.
Look at your door, If you see light under it, that means sound can get in easily. So you have to use a cheap sweep for the bottom or roll up a towel. That alone helps a lot, the next thing to do is fix the windows. Heavy curtains made for noise work better than you think. They reduce the street noise very well.
Next thing to fix is the walls. If you share a wall with a loud room, you move the furniture, that helps a lot. A big bookshelf filled with books will make a great blocker, all you have to do is put it right against that wall.
For the really annoying sounds like bass or shouting, you need mass. Hanging a thick moving blanket on the wall looks weird but works. You can hide it behind a big piece of artwork.
Also, rugs on the floor block footsteps from the floor. Remember that sound travels through ventilations too. A piece of folded shirt wedged in the ventilation opening blocks the noise but don’t block it completely. You want air to move but not the noise. Try these cheap fixes first before you spend real money on soundproof doors.
Good soundproofing probably becomes more important once people start working from home full-time. Background noise gets annoying way faster when you’re trying to focus for hours.
These are actually smart low-cost soundproofing ideas. Small fixes like sealing door gaps, adding rugs, heavy curtains, and using furniture against shared walls can noticeably reduce noise without needing a full renovation.
this ideas will definitly save a couple of bucks when implemented
I’ll make sure I try the cheap fixes first before I spend money on soundproof doors
I always soundproof wherever I be I like my things low
Very insightful and worth looking into
Good practical breakdown. Most noise issues really do come from small gaps and light materials rather than the whole structure. Simple fixes like door seals, thick curtains, rugs, and repositioning furniture can noticeably reduce sound before anyone even considers expensive soundproofing.
Watch: Roofing renovation shorts
