Roofing in Toronto: when to replace, what to spend, red flags to avoid
Planning a roof replacement in Toronto? Here is what matters most.
When to replace: Architectural shingles typically last 25-30 years in Toronto’s climate. Get it inspected at 20 years. Active leaks, interior staining, or visible granule loss in the eavestroughs = act now.
What to budget:
  • Architectural shingles (most common): $8,000 – $18,000 for a standard 1,500 sq ft home
  • Metal roofing: $15,000 – $35,000 — 40-50 year lifespan
  • Flat roof (TPO or torch-on): $8,000 – $20,000
Biggest red flags:
  • Storm chasers who appear right after a hail event
  • Request for full payment upfront
  • No WSIB certificate
  • Same-day pressure tactics
  • No written warranty on labour
The full guide is at https://telegra.ph/Roofing-Replacement-in-Toronto-Costs-Materials--Finding-Trusted-Roofers-2026-04-25
Share your own roofing experience below — what did you pay, who did you use, and would you recommend them?
GTA Roofing: What Homeowners Need to Know Before Hiring
The roofing decision is one of the more time-sensitive ones homeowners face — a failing roof cannot be deferred the way a kitchen update can. But it is also one of the categories with the highest density of predatory practices. Getting the basics right before you call anyone will save you both money and stress.
Permit requirements in Toronto
Most residential shingle-over-shingle re-roofs do not require a permit in the City of Toronto, but structural work — replacing sheathing, altering rafters, changing roofline geometry — requires a permit and inspection. When in doubt, ask your contractor to confirm in writing. A contractor who tells you “we never pull permits for roofs” without explaining why should be asked to explain the City’s by-law in detail.
What to ask a roofing contractor before signing
  • What WSIB certificate number will cover your workers on my property?
  • What labour warranty do you provide, and how do you handle callbacks?
  • What shingle manufacturer warranty does this installation qualify for? (Many require a certified installer to honour the full 30- or 50-year material warranty.)
  • Will you be doing this work or subcontracting it?
  • Can I keep a 10% holdback until the final inspection is done?
Jumping back into this one with a few things we see in the field every spring that are worth adding.
Check the attic first. Before anyone goes on your roof, spend five minutes in your attic with a flashlight. Look for dark staining on the sheathing, soft spots, or daylight coming through. A well-lit attic inspection tells you more about a roof’s actual condition than walking the exterior ever will. If the sheathing is wet or soft, you’re looking at a full tear-off and replacement — not a patch job.
Ventilation is half the battle. The number one reason we see Toronto roofs fail before they should is poor attic ventilation. When heat builds up in summer and moisture gets trapped in winter, shingles deteriorate from the underside out. If your roofer doesn’t talk about ridge vents and soffit vents, push them on it. A proper ventilation upgrade adds maybe $500-800 to a job and can extend shingle life by 5-7 years.
Spring booking tip for 2026. With lumber and material costs up significantly this spring due to ongoing tariff pressure, roofing quotes are moving. We’re already seeing suppliers put 30-60 day price-protection windows on materials. If you’re planning a roof replacement this year, getting your quote locked in now — rather than waiting until August when crews are fully booked — can save you real money.
One more red flag to add to the list above: ask the contractor who carries their liability insurance. A reputable roofer will hand you the certificate on the spot. If they go quiet or say “it’s in the truck,” walk away.
What city or neighbourhood are you in? Happy to point you toward what we’ve seen work well in different parts of the GTA.
