Replacing a regular window with a smart tint one is a total headache
The old glass window in the home office was letting in way too much afternoon glare, so I bought one of those new smart windows that automatically tints when the sun hits it. The marketing online made it seem like a quick drop in project where you just swap the glass panels and plug it into an outlet. What a total lie. Trying to wire up a window while handling a massive sheet of fragile glass is easily the most stressful thing I’ve done all month.
Getting the old window frame out without shattering the glass was a massive hassle. The previous owners had caked the outside edges in about ten layers of thick silicone sealant, so I spent an hour hacking away at the borders with a utility knife and a pry bar. When the old frame finally popped loose, a huge chunk of dry plaster crumbled off the interior wall and dropped straight onto the floor, making a giant mess before the new unit even got unboxed.
The real breakdown happened with the electrical routing side of the job. You have to run a low voltage power cable from the window frame through the wall cavity to a transformer unit, and the wire kept getting tangled on the fiberglass insulation inside the drywall. I was stuck kneeling on the floor for an hour using a metal coat hanger to fish the line through a tiny hole. Then, when I finally lifted the heavy new glass pane into the frame and screwed everything down, the smart app refused to pair with my home WiFi network.
The window works manually now and the draft is gone, but the auto tint feature is completely frozen because the system needs a firmware update that won’t download. I still have to patch that broken plaster on the wall tomorrow, and the smart control box is just dangling by a wire under the desk. I am turning off the breaker and going to make some lunch because dealing with glitchy tech is driving me crazy.
Thanks for the heads up
That sounds like one of those projects where the “smart” upgrade creates twice the amount of work you expected. Between the old sealant, damaged plaster, cable routing, and software issues, it turned into both a construction job and a tech support problem at the same time. At least the window is installed and sealed now, which is already a big part of the battle.
Removing the old frame alone was messy because of all the sealant, and some of the wall even chipped off in the process.
That’s the perfect example of “smart” tech turning into a very un-smart install at least the window still works manually and the draft is gone.
Don’t go crazy man, why don’t you get a professional to help with it
Watch: Windows renovation shorts
