Putting an above-ground pool in the backyard is an absolute test of sanity
I bought one of those giant steel frame pool kits for the kids to use this summer, thinking it would be a fun weekend setup where you just connect a few metal poles, roll out the liner, and turn on the hose. What a massive reality check. Trying to get a huge circular frame completely flat on a slightly sloped lawn turned into a brutal mix of endless shoveling and pure frustration.
The nightmare started the second I checked the ground level. My backyard looks flat, but when I laid a straight board down, one side was a full four inches lower than the other. If you fill a pool on unlevel ground, the weight of the water will literally collapse the side wall and flood the entire yard. I spent five straight hours under a scorching sun manually digging out sand, hauling heavy wheelbarrows of dirt, and dumping bags of leveling sand until my eyes were completely blurred from the heat.
The real breakdown happened when I started assembling the actual metal support structure. The plastic clips that hold the T joints together were incredibly flimsy, and every time I got one side of the circular rail locked in, the opposite side would flex, pop loose from the ground pads, and crash right back into the dirt. I was out there by myself literally trying to brace three metal legs with my feet while reaching across to slide the heavy liner into the top tracks before the whole frame twisted sideways again.
The pool is finally filled with water now and the outer steel frame is holding the structure completely solid without any bowing. The filter pump is hooked up to the side valves and humming away cleanly, and the water level is perfectly even all the way around the top border. The setup functions fine now.
Definitely one of those builds where patience at the start saves a lot of headaches later
That five-inch slope is a classic pool trap. Digging that out by hand in the heat sounds brutal, but you totally saved it from a disastrous collapse.
