Installing Floating Shelves Was Way Harder Than It Looked Online
Floating shelves always looked simple to me in renovation videos. People would drill a few holes, put the shelf up, decorate it with plants or books, and suddenly the room looked modern. It looked like one of the easiest DIY projects possible.
It really wasn’t.
The first problem was realizing walls are not always as straight as they seem. One small measuring mistake makes the shelf look crooked immediately, and once you notice it, it becomes impossible to ignore. I spent more time measuring than actually installing the shelves.
Another thing people don’t talk about enough is wall type. Drilling into drywall feels completely different from drilling into concrete or brick. Using the wrong wall anchors can make the shelves unstable, especially if they’re holding heavier items.
Still, once everything was finally installed, the room honestly looked much better. Floating shelves somehow make spaces feel cleaner without taking up floor space, which is probably why they became so popular in bedrooms, kitchens, and small apartments.
A lot of homeowners use them for decoration, but they’re useful too. In kitchens, floating shelves are often used for plates, mugs, or spice jars. In bedrooms, people usually place books, candles, or small plants on them. Even bathrooms started using floating shelves more for towels and storage.
One thing I noticed while looking for shelves is that prices vary a lot depending on material. Real wood shelves usually cost more, while lighter MDF shelves are cheaper but sometimes feel less sturdy. Stores like IKEA, Home Depot, and Home Hardware usually have beginner-friendly options for people trying DIY shelf projects for the first time.
The funny part is that floating shelves look so clean and minimal once they’re finished that people rarely realize how annoying the installation process can actually be. But after seeing the final result, I kind of understand why homeowners keep adding them to almost every modern renovation now.
The installation processes might be annoying but won’t be considering that because of the beauty shelves add to rooms
This looks Simple but improve home renovation well
Floating shelves always look easy online until you realize how important wall anchors, leveling, and stud placement actually are :sweat_smile: One small mistake and the shelf ends up crooked or weak. Patience and accurate measurements really make the difference.
They look easy to handle but turns out its harder than it looks
Nice work, i really gained alot from this
I feel like this design is also kinda space efficient
Floating shelves is not as easy as most ppl think it is, it might be complicated at times but I do believe they are the best cause they also add to the beauty of the house
Wall type also matters a lot. Drywall, brick, and concrete all need different anchors, and using the wrong ones can affect stability.
