GTA condo renovation in 2026: what needs board approval, what permits apply, and what it costs
More GTA condo owners renovated in 2026 than in the three previous years. With resale values flat and carrying costs up, staying put and upgrading made more sense than waiting on a recovery that keeps not arriving. The HomeStars 2026 survey put 34% of Ontario homeowners planning to spend more on renos this year than last – among condo owners, that number is higher.
Renovating a condo is a different process than renovating a house. Board approvals, access restrictions, noise rules, and insurance requirements all add friction that doesn’t exist in a freehold project. The gaps catch a lot of people mid-project.
What your condo corporation controls
The division is between your unit and common property. You own what’s inside your unit – the walls from the drywall inward, typically. But common property includes building systems that run through your unit even when they’re invisible. Plumbing stacks, electrical risers, and structural elements that pass through your suite often belong to the corporation.
A bathroom renovation that relocates a drain can require board sign-off even if no work touches the hallway or lobby. Request a copy of your condo’s declaration before you start planning. That document defines the boundary between what’s yours and what’s shared.
Most GTA condo corporations require advance written notice of any renovation, usually 30 to 60 days before work begins. Some require contractor insurance certificates before granting elevator access. Some restrict work to weekdays between 9 a.m. and 5 p.m. That last requirement changes how contractors sequence trades and what they charge for the job.
What needs a City of Toronto building permit
Condo board approval and building permits are separate things. You can need one without the other, or both at once.
A permit is required any time work involves moving or modifying walls (load-bearing or not, if it changes the floor plan), relocating plumbing fixtures rather than swapping them in place, adding or upgrading electrical panels or new circuits, or any structural modification.
Swapping cabinets, countertops, flooring, or fixtures in the same location generally doesn’t require one. Move the sink across the kitchen or take out a partition wall and you need a permit – and in a condo, you’ll also need to confirm the change doesn’t affect a shared wall or building system.
Toronto permit fees for a condo reno run roughly $200 to $600 depending on project value. The bigger problem is timeline: standard permits are running 6 to 10 weeks right now depending on project type, and that wait has to fit inside your contractor’s schedule or you’re paying for downtime.
What condo renovations cost in 2026
Costs in GTA condos run slightly higher than equivalent freehold work because of elevator booking fees, access restrictions, and time-limited work windows.
For a kitchen, a full gut renovation runs $22,000 to $65,000. Replacing cabinets, countertops, and appliances in the same footprint – no plumbing moves – sits around $22,000 to $35,000. Layout changes or high-end appliances push well past $50,000.
Bathrooms range from $14,000 to $40,000. A straight fixture swap with new tile and a vanity in a standard condo bathroom runs $14,000 to $20,000. Moving the toilet or the tub/shower location adds $3,000 to $8,000 in plumbing costs and triggers permit requirements.
Flooring is $8 to $18 per square foot installed. Most GTA condo boards require a minimum IIC (impact insulation class) rating for hard flooring, usually IIC 55 or higher, to limit noise to the unit below. Ask for the building’s requirement before you choose a product. Cheap laminate that fails the IIC test gets pulled, and the cost of ripping it out and starting over is yours.
Budget 15% contingency on top of your quoted number. Hidden subfloor damage, plumbing surprises behind walls, and elevator access delays all happen more often in condo projects.
Working with contractors in a condo
Not every contractor handles condo logistics well. Crews used to house work sometimes underestimate the time spent waiting for elevator access, staging materials in a lobby, and working a restricted schedule.
Before you hire: ask whether they’ve done GTA condo work before, how they handle elevator booking and who absorbs the cost if the schedule shifts, whether they carry the coverage your board requires, and whether their trades can work a weekday-only window. A contractor who’s worked in condos answers these without pause. One who hasn’t usually shows it in how they respond.
Mistakes that cost money
A few patterns show up more than others when condo renos go sideways.
Starting without board approval and hitting a stop-work order mid-project. Some corporations also require a professional restore if unpermitted work surfaces during a future sale or building inspection.
Choosing flooring before checking the IIC requirement. This is probably the most expensive single mistake in condo kitchen and living room renos – easy to avoid, hard to fix after.
Not checking how the reno affects your unit insurance. Condo unit owner policies cover improvements and betterments, but coverage limits and definitions vary. A major kitchen upgrade can push you over your betterment cap without anyone catching it until claim time.
Comparing notes with other condo owners
The details that actually help – what boards are currently requiring, which contractors understand condo logistics, which flooring products clear the IIC threshold – come from people who went through it recently. A cost guide gives you ranges; someone who finished the same project last month can tell you which contractor showed up prepared and which one had never booked an elevator in their life.
There’s an ongoing discussion at home.renovation.reviews where GTA homeowners share contractor experiences, permit timelines, and quote breakdowns. Posting what you learned – even one specific finding – earns $RENO toward your contributor tier. The leaderboard is at Home Renovation Reviews.
This information is really helpful actually
Never knew about this before. You just saved me a few extra bucks on my next Renovation.
You are right many people don’t try to see how condo renovation affect unit insurance
A lot of homeowners now renovating their homes is proof that people want to live comfortably with their house in good shape
This is very well written I learnt a lot
This article is top notch I’ll tell you that, not every contractor handles condo logistics well which isn’t good enough at all
Buh thanks for spotting what you noticed out
