Drylok Sealer, Does This Stuff Actually Hold Up Over Time?
I’m looking at cheap ways to seal up some minor moisture seeping through the cinder blocks in my utility room basement wall. It’s not a major flood or anything, just some efflorescence (that white powdery stuff) and the block feels damp to the touch after a heavy storm.
Everyone at the hardware store keeps pointing me toward Drylok masonry waterproofer paint. They claim you just scrub the wall down, slap two thick coats of this stuff on, and it creates a permanent barrier that holds back the water pressure.
It sounds almost too good to be true for a $40 can of paint. Has anyone here used it on bare block walls? Does it actually last for years, or does it just start peeling and flaking off the moment real water pressure builds up behind it? Don’t want to waste a weekend painting if it’s just a temporary band-aid.
I think it does, but I’ve never had to use it, so I’m not sure
Drylok can help for light dampness but if water pressure keeps building outside the wall it usually starts bubbling or peeling after some years. Works better as a temporary fix unless you solve the drainage issue first.
As far I as know drylok sealer is very effective , that’s why it’s recommended everywhere.
It does because I usually use it too
Drylok helps with minor dampness, but it’s not a permanent fix for real water pressure or chronic basement seepage issues.
