Cleaning out a clogged lawnmower deck is a disgusting job
The grass in the backyard got way too long after all the rain last week, and when I finally went out to cut it, the lawnmower kept sputtering and dying every five minutes. I knew exactly what the issue was before I even looked. The wet grass had turned into a thick, solid layer of green gunk packed tightly underneath the mower deck, completely blocking the blade from spinning.
Getting that nasty stuff out is easily my least favorite chore. I had to tip the heavy mower onto its side on the driveway and use an old knife to scrape the packed grass out manually. The stuff smells like rotting compost and it comes off in these giant, heavy clumps. Every time I pried a big piece loose, a shower of wet green mulch dropped straight into my face and stuck to the sweat on my arms.
The real pain was trying to get the blade off to clean the spindle area properly. The main bolt was completely seized up from rust and dried grass juice, and my socket wrench kept slipping off the nut. I had to brace the sharp blade with a block of scrap wood so it wouldn’t spin while I practically threw my entire body weight onto the wrench just to break the seal. My hand slipped on the last turn and I took a nasty scrape right across the palm.
I got the deck mostly cleared out and the blade spins freely now, but the driveway is a total disaster zone. There are giant green stains all over the concrete and the whole front yard smells like a garbage dump. I have to go find the garden hose and power wash the floor before the sun dries the grass chunks into solid brick, which is exactly how I wanted to spend my afternoon.
The day I did it which was my first I promised myself it would be the last time I’d ever do such, the experience was really bad
Wet grass always causes that. I mowed after rain once and the deck got completely packed had to scrape it out with an old knife and it smelled awful.
Wet grass buildup under a mower deck is one of those miserable maintenance jobs that gets messy fast. It sounds like you did the hard part though, especially getting that seized blade bolt loose. At least the mower should run much smoother now once everything is cleaned out properly.
Thanks for ur point of ideas, i think i will avoid things like that
Must be really stressful for you, wet grasses are so frustrating
it always ick me out
It is very disgusting
Wet grass packed under a mower deck is honestly one of the worst cleanup jobs. It turns into this heavy compost sludge that sticks to absolutely everything. At least you figured out the problem before the mower completely overheated or damaged the spindle. Your driveway might look rough now, but getting the blade spinning freely again probably saved you from a much bigger repair later.
