Changing a kitchen faucet is a great way to ruin a Saturday
Our kitchen sink has been dripping for weeks and the handle was completely loose, so I bought a new stainless steel faucet online and figured it would be an easy swap. Just unscrew the old pipes, drop the new fixture into the hole, and tighten it up. What a complete joke. I spent three hours laying on my back inside a dark cabinet getting covered in rust flakes and muddy water.
The space under the sink is incredibly cramped. I had to empty out all the dish soap bottles and trash bins just to wedge my shoulders into the cabinet, and my head was literally jammed against the garbage disposal unit the entire time. The old mounting nut was so rusted onto the brass threads that my regular wrench couldn’t even grip it. Every time I pulled hard, the wrench slipped and I smashed my knuckles directly into the sharp metal pipes.
When I finally broke the old bolt loose and pulled the pipe out, a bunch of gross, stagnant water leaked out of the supply line and soaked the sleeve of my shirt. Then, trying to get the new flexible hoses to reach the hot and cold valves was another total nightmare because the new lines were about two inches shorter than the old ones. I had to scramble out from under the counter, drive all the way to the hardware store covered in gray grime, and hunt down some pipe extensions just to finish the job.
It is hooked up now and the leak stopped, but the faucet sits slightly crooked because the metal sink basin is warped underneath. I don’t even care at this point. The kitchen floor is covered in wet towels, my neck is completely stiff from laying on that hard wood cabinet floor, and I’m just leaving the tools in the sink because I am completely done with it.
Ur ideas are really great, keep on sharing them
Oh my sorry about that
Those old mounting nuts get stuck like crazy too. Sometimes it feels like they’ve fused to the pipe over time
The experience you had is quite intriguing buddy
Changing a kitchen faucet is what is easy and it won’t takes time so trying to get it done every or mostly on weekends is nice
Hope you were able to finish the job, you can always continue later.
If you didn’t
I had a similar problem so time ago . I couldn’t fix it so I decided to call a plumber
Under-sink plumbing always looks way easier in videos than it is in real life. Working upside down in a tiny cabinet while fighting rusted fittings is exhausting fast. Honestly, the fact you got the leak stopped at all after dealing with short hoses and seized hardware is already a win. The slightly crooked faucet sounds a lot less important after a day like that.
That’s a brutal under-sink job once you’re upside down in rust and cramped space, it stops being “simple DIY” real quick.
