Bathroom renovation permits in Ontario: what actually triggers one (and what happens if you skip it)
When does a bathroom renovation need a permit in Ontario?
More often than most homeowners expect. Ontario’s Building Code applies whenever work touches structure, plumbing, electrical, or HVAC, and a lot of bathroom projects hit at least one of those.
Moving or adding plumbing is the most common trigger. Relocating a toilet, adding a second sink, roughing in a shower where there wasn’t one all require a plumbing permit, and the drain rough-in has to be inspected before it gets enclosed. Electrical work is similar: adding a circuit for heated floors, upgrading an exhaust fan, or any AFCI/GFCI panel changes require an electrical permit. Ontario requires GFCI protection within 1.5m of water sources.
Structural changes matter too. Moving or removing a wall, even a non-load-bearing one, usually triggers a building permit, especially in bathroom expansions or powder-room-to-full-bath conversions. Changing a window’s size or location falls into the same category in most GTA municipalities.
What doesn’t require a permit: cosmetic work. Retiling an existing shower (same footprint, same drain), swapping out a vanity, replacing a toilet, repainting walls, generally no permit needed.
What actually happens if you skip it
Plenty of homeowners skip permits to avoid the timeline and the inspection. The consequences aren’t usually immediate, but they tend to surface at the worst possible time.
Title searches at sale are the most common problem. Lawyers flag unpermitted work as a gap in the building record. You’ll either retroactively permit the work (which usually means opening walls so inspectors can see what they’re approving), negotiate a price reduction with the buyer, or lose the deal. Getting caught mid-closing is not a position you want to negotiate from.
Insurance is the other risk. If a burst pipe or electrical fire originates in a bathroom where unpermitted electrical work was done, your insurer has grounds to deny the claim. That’s not a theoretical edge case. It happens, and the financial exposure is significant.
Retroactive permits almost always require opening finished work. Inspectors can’t sign off on what they can’t see. A $300 permit upfront versus demo, redo, and a retroactive permit fee is not a close comparison.
What the permit process actually involves
Most GTA municipalities accept residential permit applications through an online ePLAN system. You submit drawings (hand-drawn works fine if they’re legible), a site plan, and a description of the scope. Review times for residential projects run 10 to 30 business days, sometimes faster for straightforward scopes.
Once issued, inspections happen at staged milestones. Plumbing rough-in gets inspected before the drain is enclosed. Electrical rough-in before drywall. Final inspection when the work is complete.
If you’re using a licensed contractor, they’ll often pull the permit themselves, which shifts some legal responsibility to them. Get that confirmed in writing either way, because the permit holder is legally on the hook for the work meeting code.
Permit fees in the GTA generally run $200 to $1,000 for a standard bathroom renovation, depending on scope and municipality. In Toronto, applications go through the Toronto Building portal. York Region, Peel, Halton, and Durham each have their own building department portals.
Sort it out before the demo crew arrives
The conversations to have before signing a contract: who is pulling the permit, what inspections are required and when, whether permit fees are in the contract price, and whether the contractor has worked in your specific municipality before. Timelines and inspector expectations vary by city, sometimes by quite a bit.
A bathroom renovation holds its value well at resale in the GTA, but only if the work is permitted. Unpermitted work turns into a title search problem or an insurance dispute at exactly the point when you can least afford to deal with either.
Earn $RENO tokens for helping others navigate questions like this. Visit the welcome topic to link your Solana wallet and start tracking contributions.
