Bathroom Renovation in Toronto: What 2026 Actually Costs
We get a lot of questions on the forum about bathroom renos - what is reasonable to spend, what is worth skipping, and where the budget usually runs away on you. I put together a full guide on the blog this week that walks through exactly that, and I want to share the key points here because they are worth discussing.
The numbers first
For a Toronto bathroom that keeps its existing layout - no drain moves, no structural changes - but gets a full cosmetic and fixture overhaul, you are typically looking at mid-twenties to upper thirties (thousand CAD) in 2026. If you are expanding a shower footprint, adding heated floors, or speccing custom glass, that pushes into the forties to mid-fifties. High-spec work - microcement walls, a freestanding tub, integrated lighting scenes, custom millwork - comfortably crosses the high fifties and up.
What surprises homeowners is how little those numbers shift based on fixture brand, and how much they shift based on what is behind the walls.
The thing nobody quotes you for
In Toronto and Newmarket especially, we still open floors and find patchwork plumbing beside undersized venting. Pre-1990 housing across the GTA often has at least partial subfloor damage at the tub edge or around the toilet flange - you do not know until you are in there. Budget a 10-15% contingency if your home is from before 1985. That is not pessimism, that is just what we see after 50 years and 30,000+ projects across Southern Ontario.
Where the money is well spent in 2026
Three things consistently get the most appreciation from clients a year after the reno, regardless of budget tier:
1. Heated floor coils - modest cost to add during a reno ($1,500-$4,000 depending on room size), but cold November mornings become genuinely different. The cost to add them after tiles are down is extreme. If a bathroom renovation is happening anyway, it is almost always worth adding.
2. High-CRI balanced lighting at the mirror - not the 5000K hospital-panel look that makes skin go grey. You want 2700-3000K ambient and task lighting from the sides of the mirror, not just the top. This is the single most-noticed quality upgrade a year later.
3. A properly spec’d quiet ventilation fan - mold prevention and daily sound quality. Wildly underrated.
None of these are glamorous. None are what people spend hours choosing on Pinterest. But they are what clients thank you for at the one-year mark.
What 2026 is actually trending toward
Away from the cold grey minimalism that peaked around 2022-23. The direction right now is warmer - teak and walnut vanities, large-format porcelain with fewer grout lines, warm nickel or brushed brass hardware, layered lighting. Curbless showers and floating vanities continue to dominate because they make modest-sized bathrooms breathe.
The best design advice I can give: restraint reads as confidence. Pick one material story and commit to it rather than doing large-format tile plus a chevron accent plus a patterned floor.
The full guide
For the complete framework - layout decisions, vanity strategy, shower vs. tub calculus, heated floor and lighting budgeting, and a realistic timeline breakdown - I wrote this up in full: Modern Bathrooms 2026: Design Guide, Vanities & Showers
Also worth browsing: our Most Commonly Asked Questions thread covers contractor vetting, permits, and what to watch for across all renovation types.
If you are planning a bathroom reno in the GTA this spring or summer, where are you at in the process? Budget allocation, layout decisions, or figuring out what might be hiding behind your walls - happy to work through it here.
Frequently Asked Questions: Bathroom Renovation Costs in Toronto 2026
Q: What does a full bathroom renovation cost in Toronto in 2026?
For a bathroom that keeps its existing layout — no drain moves, no structural changes — a full cosmetic and fixture overhaul typically runs $25,000 to $38,000. Expanding a shower footprint, adding heated floors, or specifying custom glass pushes that to $40,000 to $55,000. High-spec work — microcement walls, a freestanding tub, custom glass, integrated lighting — starts at $58,000 and up.
Q: What hidden costs should I plan for in a Toronto bathroom renovation?
Pre-1985 homes across the GTA frequently have subfloor damage at the tub edge or around the toilet flange — you find out when demolition begins. Pre-1990 plumbing often includes partial patchwork or undersized venting that needs remediation to close a permit. Budget a 10 to 15 percent contingency if your home predates 1985. After 50 years and 30,000+ projects across Southern Ontario, this is the number that consistently surprises homeowners.
Q: Which bathroom upgrades have the best long-term value?
Three consistently earn the most appreciation from clients twelve months post-completion: heated floor coils (modest to add during a reno, prohibitively expensive to add after tiles are down); high-CRI balanced mirror lighting at 2700–3000K positioned from the sides rather than overhead; and a properly specified quiet ventilation fan for mould prevention and daily sound quality. None are glamorous. All are things clients thank you for at the one-year mark.
Q: What bathroom design trends are popular in the GTA in 2026?
Away from the cold grey minimalism that peaked around 2022–23. The current direction is warmer — teak and walnut vanities, large-format porcelain with fewer grout lines, warm nickel or brushed brass hardware, layered lighting, curbless showers, and floating vanities. The best single piece of design advice: choose one material story and commit to it, rather than mixing multiple competing accent elements.
Watch: Bathrooms renovation shorts
